khany ®   02-Feb-2019 16:37
Passage Planning Guidelines
Year: 2018
Author: Witherby Publishing Group
Genre: Handbook
Publisher: Witherby Publishing Group
Edition: 5
ISBN: 978-1-85609-778-9
Quality: OCR without errors
Pages count: 147
Description: Passage Planning Guidelines focuses on the Appraisal and Planning stages of voyage planning using traditional methods, paper charts and ECDIS, with a fully worked example based on paper charts. This updated edition incorporates the latest IHO S52 Performance Library 4.0 which came in to effect in Sep 2017 with advice on the significant operational impact of PL 4.0.
Abyrax   02-Feb-2019 22:17
Хорошая книжка, сам делал скан и в итоге потерял где то)
ECDIS Passage Planning and Watchkeeping - Witherby Publishing Group [2018, PDF]
Passage Planning Guidelines - David Salmon [2015, DOC]
Teamwork on the Nav Bridge - Witherby Publishing Group [2019, PDF]
Safe Nav Watch - Witherby Publishing Group [2019, PDF]
Passage Planning Guidelines - Witherby [2021, PDF]
Passage Planning Guide: English Channel, Dover Strait and Southern North Sea - Witherby [2021, PDF]
Passage Planning Guidelines 6th edition - Witherby [2019, PDF]
Tidal Stream Charts and Tables: English Channel and Dover Strait - Witherby [2021-2023, PDF]
ECDIS Passage Planning and Watchkeeping - Witherbys [2021, JPEG]
Tidal Stream Charts and Tables: English Channel, Dover Strait and Southern North Sea - Witherby…
  • Topic closed
The time now is: Today 15:55
