virtual ®   19-Jan-2019 07:48
Volatile Organic Compound Emissions from Cargo Systems on Oil Tankers (First edition)
Year: 2019
Author: OCIMF
Pages count: 21
Description: Volatile Organic Compounds (VOCs) are any organic compounds that have an initial boiling point less than or equal to 250°C (482°F) when measured at a standard atmospheric pressure of
101.3 kPa. VOCs are a mixture of light end hydrocarbons (such as methane, ethane, propane or butane) that evaporate within the range of normal atmospheric conditions. VOCs are generated when cargo flashes in the piping system from the source to the cargo tanks, and from evaporation from the oil surface inside the cargo oil tanks during and after loading. During loading of crude oil tankers and the subsequent vessel transit, VOCs may be released to the atmosphere together with the inert gas.
Volatile-Organic-Compound-Emissions-from-Cargo-Systems-on-Oil-Tankers.pdf
Download [688 B]
Instruction Manual for Freshwater Generator Type D-PU-2-36-CAS100/125
Inert gas systems - The use of inert gas for the carriage of flammable oil cargoes (First edition)…
Liquefied Petrolium Gas Tanker Practice - Captain T W V Woolcoot [1977, PDF]
Inert gas systems: The use of inert gas for the carriage of flammable oil cargoes - Oil Companies…
Hydrocarbon Management HM 40: Guidelines for the crude oil washing of ships’ tanks and the heating…
Oil Tanker Operations Manual (OTM) - Unknown [2020, PDF]
Specialised Training for Oil Tanker (Model Course 1.02) - IMO [2006, PDF]
LPGC Simplified Cargo Measurements, Cargo Works and Stability - Edulandsea [2020, HTML, PDF]
API - Effects of Oil and Chemically Dispersed Oil in the Environment - API [2001, PDF]
Miracle Tank Cleaning Guide - Miracle [2008, PDF]
The time now is: Today 13:19
