evseev.sergey9284 ®   11-Oct-2017 18:51
Miracle Tank Cleaning Guide
Year: 2008
Author: Miracle
Genre: Handbook
Publisher: ChemServe GmbH
Number of pages: 1159
Description: By way of additional information, MIRACLE will give warnings about certain known incompatibilities in the loading of certain chemicals in adjacent tanks (adjacent cargo compatibility test) or about the incompatibility of successive loadings of certain chemicals in the same tanks (FOSFA compatibility).
These warnings contained in the MIRACLE-program are based on generally known information or information given by the producers of the chemicals and are not given with the guarantee that the information is correct, up to date or complete.
In addition, MIRACLE also contains further directions for use connected with known incompatibility between certain materials used for the coating of the tanks and chemicals (coating resistance list). These further directions for use are based on information given by the manufacturers of the respective tank coating or the respective chemicals and are also not given on the basis of any guarantee as to whether the information is correct, up to date or complete.
The above additional directions for use referred to do not constitute part of the contractual performance of the service provider and can be limited or removed at any time.
1. GENERAL TRADING CONDITIONS..............................................................................................................................6
2. INTRODUCTION..............................................................................................................................................................13
3. TANK CLEANING............................................................................................................................................................13
3.1. GENERAL...........................................................................................................................................................................13
3.2. TANK CLEANING STEPS....................................................................................................................................................14
3.2.1. PLANNING .......................................................................................................................................................................14
3.2.2. PRE-CLEANING................................................................................................................................................................15
3.2.3. FINAL CLEANING .............................................................................................................................................................15
3.2.4. VERIFICATION OF RESULTS..............................................................................................................................................15
3.3. DESCRIPTION OF CLEANING STEPS..................................................................................................................................15
3.4. PHYSICAL PROPERTIES ....................................................................................................................................................16
3.5. PRODUCT CHARACTERISTICS...........................................................................................................................................17
3.6. SURROUNDING CONDITIONS.............................................................................................................................................18
3.7. CLEANING HARDWARE.....................................................................................................................................................18
3.8. CLEANING AGENT.............................................................................................................................................................19
3.9. PUMPS, PIPES AND VALVES ..............................................................................................................................................20
3.9.1. PUMP COFFERDAM ..........................................................................................................................................................20
3.10. CLEANING METHODS .......................................................................................................................................................23
3.10.1. BUTTERWORTH ...............................................................................................................................................................23
3.10.2. INJECTION CLEANING......................................................................................................................................................23
3.10.3. RECIRCULATION CLEANING ............................................................................................................................................23
3.10.4. RINSING...........................................................................................................................................................................25
3.10.5. VENT/MOP/DRY..............................................................................................................................................................25
3.10.6. HAND SPRAY...................................................................................................................................................................25
3.10.7. STEAMING .......................................................................................................................................................................26
3.10.8. SOLVENT STEAMING .......................................................................................................................................................26
3.10.9. SOLVENT SPRAYING........................................................................................................................................................26
3.10.10. SOLVENT WASH ..............................................................................................................................................................26
3.10.11. CHLORIDE REMOVAL.......................................................................................................................................................27
3.10.12. DYE OUT.........................................................................................................................................................................27
3.11. PICKLING AND PASSIVATION............................................................................................................................................27
3.11.1. PICKLING.........................................................................................................................................................................27
3.11.2. PASSIVATION...................................................................................................................................................................28
3.11.3. SAFETY CONSIDERATIONS...............................................................................................................................................28
3.11.4. PALLADIUM TEST............................................................................................................................................................28
4. SAFETY ..............................................................................................................................................................................29
4.1. OPERATIONS PLANNING ...................................................................................................................................................29
4.2. HAZARDS...........................................................................................................................................................................29
4.3. FIRE &EXPLOSION...........................................................................................................................................................30
4.3.1. STATIC ELECTRICITY.......................................................................................................................................................31
4.3.2. SIMPLE EXPLANATION FOR STATIC ELECTRICITY ...........................................................................................................31
4.3.3. UNBOUNDED OBJECTS ....................................................................................................................................................36
4.4. ASPHYXIATION..................................................................................................................................................................39
4.5. REACTION WITH WATER...................................................................................................................................................40
4.6. RISK...................................................................................................................................................................................40
4.7. EMERGENCY RESPONSE INFORMATION...........................................................................................................................41
4.7.1. STRUCTURE.....................................................................................................................................................................41
4.7.2. GENERAL GUIDANCE.......................................................................................................................................................41
4.7.3. CHARACTERISTICS/HAZARDS..........................................................................................................................................41
3
4.7.4. PERSONAL PROTECTION ..................................................................................................................................................41
4.7.5. SPILLAGE.........................................................................................................................................................................42
4.7.6. FIRE.................................................................................................................................................................................42
4.7.7. FIRST AID........................................................................................................................................................................42
4.7.8. ESSENTIAL PRECAUTIONS FOR PRODUCT RECOVERY......................................................................................................43
4.7.9. PRECAUTIONS AFTER INTERVENTION ..............................................................................................................................43
4.7.10. DISCLAIMER....................................................................................................................................................................43
5. STANDARDS......................................................................................................................................................................43
6. COATINGS.........................................................................................................................................................................44
6.1. ZINC SILICATES ................................................................................................................................................................44
6.1.1. CLEANING OF ZINC SILICATE COATED TANKS .................................................................................................................44
6.1.2. VOLATILE LIQUIDS ..........................................................................................................................................................44
6.1.3. NON-VOLATILE LIQUIDS ..................................................................................................................................................45
6.2. EPOXY COATINGS .............................................................................................................................................................45
6.2.1. ABSORPTION/DESORPTION..............................................................................................................................................46
6.2.2. CLEANING OF EPOXY COATED TANKS..............................................................................................................................46
6.2.3. POTENTIAL CONTAMINATION OF NEXT CARGO ................................................................................................................47
7. TANK INSPECTION.........................................................................................................................................................48
7.1. TESTING ............................................................................................................................................................................48
7.1.1. PERMANGANATE TIME TEST...........................................................................................................................................48
7.1.2. WATER MISCIBILITY (HYDROCARBON TEST)...................................................................................................................49
7.1.3. CHLORIDE TEST...............................................................................................................................................................50
7.1.4. COLOUR TEST .................................................................................................................................................................51
7.1.5. UV TEST .........................................................................................................................................................................51
7.1.6. ACID WASH.....................................................................................................................................................................52
7.1.7. NVM TEST......................................................................................................................................................................53
7.1.8. COD TEST.......................................................................................................................................................................53
7.1.9. METHANOL TEST KIT ......................................................................................................................................................53
7.2. WALL WASH PROCEDURE................................................................................................................................................54
8. TROUBLESHOOTING.....................................................................................................................................................56
9. DEFINITIONS....................................................................................................................................................................58
9.1. VISCOSITY.........................................................................................................................................................................59
9.2. WATER SOLUBILITY/MISCIBILITY...................................................................................................................................59
9.3. PHASES ..............................................................................................................................................................................60
9.4. HARDNESS .........................................................................................................................................................................61
9.5. SAPONIFICATION...............................................................................................................................................................62
9.6. VAPOUR PRESSURE...........................................................................................................................................................62
9.7. BOILING POINT .................................................................................................................................................................63
9.8. FLAMMABILITY.................................................................................................................................................................63
9.8.1. UPPER FLAMMABLE LIMIT ..............................................................................................................................................63
9.8.2. LOWER FLAMMABLE LIMIT .............................................................................................................................................63
9.8.3. FLASHPOINT ....................................................................................................................................................................64
9.9. INERT GAS.........................................................................................................................................................................64
9.10. DENSITY ............................................................................................................................................................................65
9.11. EMULSION .........................................................................................................................................................................65
9.11.1. SURFACE TENSION...........................................................................................................................................................65
9.11.2. DETERGENT.....................................................................................................................................................................65
4
9.11.3. SURFACE-ACTIVE AGENT ................................................................................................................................................65
9.12. POLYMERISATION.............................................................................................................................................................66
9.13. DRYING .............................................................................................................................................................................66
9.14. DRYING OIL.......................................................................................................................................................................67
9.14.1. CLASSIFICATION OF OILS ................................................................................................................................................67
9.15. DEFINITION PH .................................................................................................................................................................68
9.16. COLOUR ............................................................................................................................................................................68
9.16.1. ASTM COLOUR...............................................................................................................................................................69
9.16.2. N.P.A. COLOUR...............................................................................................................................................................69
9.16.3. APHA COLOUR...............................................................................................................................................................69
9.16.4. SAYBOLT COLOUR ..........................................................................................................................................................69
9.16.5. GARDNER COLOUR..........................................................................................................................................................69
9.16.6. OTHER COLOUR SCALES .................................................................................................................................................69
9.16.7. APPROXIMATE COLOUR SCALE EQUIVALENTS................................................................................................................70
10. MARPOL ............................................................................................................................................................................70
10.1. ANNEX I: ...........................................................................................................................................................................70
10.1.1. ANNEX I SPECIAL AREAS .................................................................................................................................................71
10.2. ANNEX II:..........................................................................................................................................................................72
10.2.1. SUMMARY OF MARPOL ANNEX II REQUIREMENTS WILL ENTER INTO FORCE 01.01.2007 ............................................72
10.2.2. STRIPPING REQUIREMENTS ..............................................................................................................................................73
10.2.3. WASHING REQUIREMENTS ..............................................................................................................................................74
11. ATTACHMENTS...............................................................................................................................................................78
11.1. TANK CLEANING PLAN.....................................................................................................................................................78
11.2. SPECIFIC CLEANING PROCEDURE....................................................................................................................................79
11.3. LIST OF IMO APPROVED CLEANING AGENTS .................................................................................................................80
List of Synoniems........................................................................................................................................88
Cleaning Proposals (Database).......................................................................................................142
Emergency Response (ERI Cards)..............................................................................................1098
Figures
FIGURE 1 PATTERN OF CLEANING MACHINE..................................................................................................................................19
FIGURE 2 POSSIBLE LEAKS OF PUMP SEAL .....................................................................................................................................21
FIGURE 3 PUMP COFFERDAM.........................................................................................................................................................22
FIGURE 4 INJECTION CLEANING ARRANGEMENT............................................................................................................................23
FIGURE 5 RECIRCULATION CLEANING ARRANGEMENT..................................................................................................................24
FIGURE 6 RECIRCULATION CLEANING VIA SERVICE TANK ARRANGEMENT....................................................................................25
FIGURE 7 FRICTION CREATES CHARGED DROPLETS .......................................................................................................................36
FIGURE 8 ACCUMULATION OF CHARGE IN NON-BONDED OBJECT ..................................................................................................37
FIGURE 9 ELECTROSTATIC DISCHARGE .........................................................................................................................................38
FIGURE 10 DISCHARGE IGNITES FLAMMABLE ATMOSPHERE..........................................................................................................39
FIGURE 11 ZINC COATING.............................................................................................................................................................44
FIGURE 12 EPOXY COATING .........................................................................................................................................................45
FIGURE 13 ABSORPTION/DESORPTION OF CARGO IN TANKLINING................................................................................................46
FIGURE 14 SPECTROMETER ...........................................................................................................................................................52
FIGURE 15 ABSORBANCE GRAPH ..................................................................................................................................................52
FIGURE 16 VISCOSITY ...................................................................................................................................................................59
FIGURE 17 PHASES........................................................................................................................................................................60
FIGURE 18 SAPONIFICATION .........................................................................................................................................................62
FIGURE 19 BOILING POINT ............................................................................................................................................................63
FIGURE 20 FLAMMABILITY COMPOSITION DIAGRAM - HYDROCARBON GAS/AIR/INERT GAS MIXTURE.......................................64
FIGURE 21 POLYMERISATION OF ETHYLENE .................................................................................................................................66
Miracle Tank Cleaning guide 2008.pdf
Download [10 KB]
Arcan   11-Oct-2017 20:00
Было бы неплохо добавить скриншоты страниц. И побольше в description описать.
Правила оформления релизов https://seatracker.me/viewtopic.php?p=8288#8288 особенно пункт 15
Программа для создания скриншотов
Snagit v.11 - Программа для создания скриншотов и записи видео с экрана монитора [2012]
Разработчик:-Платформа: -Разрядность: 32bit / 64bit | Язык интерфейса: Английский, Русский | Таблэтка: Ключ-Системные требования:
Open released by zxc
5
alexn23   24-Oct-2017 01:19
Серьезный документ для тех, кто вовлечен в перевозку химии наливом, или должен заниматься мойкой грузовых танков химовозов.
Кому надо, невероятно полезное издание.
Tank Cleaning Manual - Drew Marine [2005, PDF]
Chemical Tanker Mamual - Synergy Group [2021, PDF]
Oil Tanker Operations Manual (OTM) - Unknown [2020, PDF]
Tanker Safety Training (Liquefied Gas) Specialised level - Seamanship International and Witherbys…
Liquefied Gas Handling Principles on Ships and in Terminals 3th Edition - McGUlRE and WHITE [2000,…
Guidelines for Hazardous Area Classification and Electrical Installations of Tankers, 2010 - CCS…
Crude oil tanker "British Kestrel" Cargo operating manual - Worldwide Marine Technology…
ISGOTT - OCIMF [2006, PDF]
The time now is: Today 15:36
