batd ®   12-Jan-2019 12:20
Cruising the Southern and Western Caribbean A Guide to the Ships & the Ports of Call
Year: 2003
Author: Larry H. Ludmer
Pages count: 312
Description: This book is intended to serve as an information source for planning a Caribbean cruise, as well as a companion to take with you on land in this beautiful region. It will enable both first-time and experienced travelers to determine the particular cruise that’s right for them and, once the trip has begun, to get the most enjoyment from their time on board and ashore.
Experienced travelers rarely get their information from one source, and I wouldn’t expect that you would so limit yourself. Because the port information is geared to the general traveler with only a single day of time available, you should do further research if a particular destination is of special interest to you. Obtaining a guidebook on that place would be of great use. As you peruse this book you’ll learn that a host of cruise lines serve the Caribbean. I encourage everyone to visit their local travel agent and grab a stack of cruise brochures. In combination with the information in this book, they will further help you to decide which ship is right for you. Always remember, however, that glossy brochures are carefully designed to get your business. Be a thoughtful consumer.
Enjoy your cruise vacation!
Cruising the Mexican Riviera & Baja A Guide to the Ships & the Ports of Call - Larry H. Ludmer [2005...
Cruising The Mediterranean - Larry Ludmer [2006, PDF]
Cruising Alaska A Traveler’s Guide to Cruising Alaskan Waters & Discovering the Interior 5th edition...
Cruising Alaska A Guide to the Ports of Call - Larry H. Ludmer [2008, PDF]
West Country Cruising Companion - Mark Fishwick [2021, EPUB]
The Unofficial Guide to the Disney Cruise Line 2024 (Unofficial Guides) - Erin Foster [2023, EPUB]
C-MAP Plan2Nav - Marine Navigation v.1.6.1 - C-MAP by Jeppesen [2016] [Android]
A Yachting Pilot For CRETE - Tony Cross [2015, PDF]
Cruising for Cowards: A Practical A-Z for Coastal and Offshore Sailors - Liza Copeland, Andy Copelan...
Master’s Guide to Compliance in Canada - O’Brien’s [2011, PDF]
The time now is: Today 01:40
