batd ®   12-Jan-2019 12:09
Cruising the Mexican Riviera & Baja A Guide to the Ships & the Ports of Call
Year: 2005
Author: Larry H. Ludmer
Pages count: 293
Description: This book is intended to serve as an information source for planning a cruise to Mexico’s Pacific coast, as well as a companion to take with you on land while exploring this fascinating and beautiful country. It will enable both the first-time and experienced cruise traveler to select a cruise that’s right for them and, once the trip has begun, to get the most enjoyment from their time both onboard ship and while ashore.
Experienced travelers rarely get their information from one source, and I wouldn’t expect that you would so limit yourself. Because the port information offered in this book is geared to the general traveler with only a single day available, you should do further research for any port of call that is of particular or special interest to you. Obtaining a guidebook on that place would be the logical next step.
As you peruse this book you’ll learn that there are many cruise lines offering service to the Mexican Riviera and Baja. I strongly encourage you to visit your local travel agent and grab a stack of cruise brochures. In combination with the information in this book, they will further help you to decide which ship and itinerary is right for you. Always remember, however, that those glossy brochures are carefully designed by slick marketing experts to get your business. Be a thoughtful consumer.
Enjoy your cruise vacation to sunny Mexico!
Download [4 KB]
Cruising the Southern and Western Caribbean A Guide to the Ships & the Ports of Call - Larry H. Ludm...
Cruising The Mediterranean - Larry Ludmer [2006, PDF]
Cruising Alaska A Traveler’s Guide to Cruising Alaskan Waters & Discovering the Interior 5th edition...
Cruising Alaska A Guide to the Ports of Call - Larry H. Ludmer [2008, PDF]
C-MAP Plan2Nav - Marine Navigation v.1.6.1 - C-MAP by Jeppesen [2016] [Android]
A Yachting Pilot For CRETE - Tony Cross [2015, PDF]
Tourism Agenda of the Mexican Gulf and Pacific with RNC - SEMAR [2018, PDF]
Ocean Sailing - Robert James [1980, PDF]
The Unofficial Guide to the Disney Cruise Line 2024 (Unofficial Guides) - Erin Foster [2023, EPUB]
Cruising Guide to Belize and Mexico’s Caribbean Coast - Rauscher F. [1991, PDF]
The time now is: Today 00:01
