marlamamba ®   17-Dec-2018 14:51
Propulsion Trends in LNG Carriers
Year: 2013
Author: MAN Diesel & Turbo
Genre: Research papers
Publisher: MAN Diesel & Turbo (Copenhagen, Denmark)
Pages count: 20
Description: Because of the relatively high price of natural gas today, it may be an economical advantage to utilise the expensive boil-off gas in a dual fuel (heavy fuel and compressed natural gas) diesel engine for main propulsion, as there will be no need for forced boil-off. A possibility is also to reliquefy the expensive boil off gas by means of a reliquefaction plant, and then use an ordinary heavy fuel oil driven diesel engine for main propulsion. In both cases, fuel savings are obtained compared to the standard steam turbine system.
This paper deals with those questions
Propulsion Trends in LNG Carriers.pdf
Download [1 KB]
Propulsion Trends in Container Vessels - MAN Diesel & Turbo [2013, PDF]
Propulsion Trends in Bulk Carriers - MAN Diesel & Turbo [2014, PDF]
Propulsion Trends in Tankers - MAN Diesel & Turbo [2013, PDF]
Ice Classed Ships Main Engines - MAN Diesel & Turbo (Copenhagen, Denmark) [2013, PDF]
Kongsberg SP Dual Fuel Simulator v.2.4.0.0259 - Kongsberg [2009]
LNGC-optimised designs of ME-GI engines and fuel gas supply systems - MAN B&W [2020, PDF]
ME-GI Dual Fuel MAN B&W Engines A Technical, Operational and Cost-effective Solution for Ships Fuell...
Hydrogen co-combustion in ICE - CMB [2019, PDF]
Guidelines for Operation on Fuels with less than 0.1% Sulphur - MAN Diesel & Turbo [2104, PDF]
Kongsberg SP Dual Fuel Simulator v.2.4.0.0259 Instructions Manual- Kongsberg [2009]
The time now is: Today 03:41
