gillnumil ®   08-Nov-2018 21:52
A Review of LPG Cargo Quantity Calculations
Year: 1985
Author: SIGTTO
Publisher: SIGTTO
Pages count: 26
Description: The purpose of this review is to clarify some of the myths and mysteries surrounding LPG cargo quantity calculation. These problems arise because there is no one method, embodied within an internationally agreed standard, of carrying out the quantity calculation. The review is broken down into a number of sections to cover the subject from both the ship side and the terminal viewpoint. In the introduction, the reasons behind the concept of weight in air are discussed. The second section details one method of carrying out the calculation of ship or shore tank quantity, followed by a cargo calculation. The third section considers alternative procedures that may also be used for quantity calculations. Subsequent sections are devoted to calculations from the terminal viewpoint, including comparisons that may be expected between ship and shore figures. The final section is devoted to a consideration of likely future developments in this area, in particular, of documents planned for formalizing and enhancing calculation procedures.
Additional info: Prepared by Dr. Eric R. Robinson.
1. Introduction
2. Inventory and Ship Cargo Calculation
3. Variatoins Upon a Theme
4. Shore Terminal Considerations
5. Other Cargoes
6. Future Developments
7. Conclusions
Appendix 1: Weight in Air Conversions
Appendix 2: Calculations of Section 2
Appendix 3: Calculations of Section 3.1
Appendix 4: Calculation of Section 3.2
Appendix 5: Calculation of Section 3.3
Appendix 6: The Coastald Equation
Appendix 7: Corrections for Direct Weighing
Appendix 8: The Klosek -McKinley Density Prediction
Appendix 9: Calorific Value Determination
SIGTTO A Review of LPG Cargo Quantity Calculations.pdf
LNG Transfer Arms and Manifold Draining, Purging and Disconnection Procedure - SIGTTO [2012, PDF]
Liquefied Petrolium Gas Tanker Practice - Captain T W V Woolcoot [1977, PDF]
Alternative Futures in Cyber Security - U.S. Coast Guard, Ventus Executive Solutions LLC [2016, PDF]
Ship Resistance and Flow - Lars Larsson & Hoyte C. Raven [2010, PDF]
SmartCAL-Load v.2.6 - SmartCALWorx [2019]
Quantity Calculations - LPG and Chemical Gases - SIGTTO [1997, PDF]
Guidance on the application of correction factors and voyage adjustments for calculation of…
BLU Code - IMO [2003, PDF]
Inspection Guidelines For Ships Carrying Liquefied Gases In Bulk - SIGTTO [1998, PDF]
Bulk Carriers - Guidance and Information on Bulk Cargo Loading and Discharging to Reduce the…
The time now is: Today 15:13
