Nemo ®   21-Oct-2018 20:24
REED'S Motor Engineering Knowledge for Marine Engineers
Year: 2013
Author: Paul Anthony Russell, Thomas D. Morton, Leslie Jackson
Genre: Textbook
Publisher: Reeds Marine Engineering
Edition: 1
ISBN: 9781408175996
Number of pages: 310
Description: The object of this book is to prepare students for the Certificates of Competency of the Department of Transport in the subject of Motor Engineering Knowledge.
The text is intended to cover the ground work required for both examinations. The syllabus and principles involved are virtually the same for both examinations but questions set in the First Class require a more detailed answer.
The book is not to be considered as a close detail reference work but rather as a specific examination guide, in particular all the sketches are intended as direct application to the examination requirements.
The best method of study is to read carefully through each chapter, practising sketchwork, and when the principles have been mastered to attempt the few examples at the end of the chapter.
Finally, the miscellaneous questions at the end of the book should be worked through. The best preparation for any examination is to work on the examples, this is difficult in the subject of Engineering Knowledge as no model answer is available, nor indeed any one text book to cover all the possible questions. As a guide it is suggested that the student finds his information first and then attempts each question in the book in turn, basing his answer on either a good descriptive sketch and writing or a description covering about lf pages of A4 paper in f hour.
REED'S Motor Engineering Knowledge for Marine Engineers.pdf
REEDS Vol 9: Steam Engineering Knowledge for Marine Engineers - Thomas D. Morton [2003, PDF]
REEDS Vol 3: Applied Thermodynamics for Marine Engineers - Paul Anthony Russell, William Embleton,…
REEDS Vol 5: Ship Construction for Marine Engineers - Paul Anthony Russell, E A Stokoe [2016, PDF]
REEDS Vol 1: Mathematics for Engineers - William Embleton [1976, PDF]
REEDS General Engineering Knowledge for Marine Engineers - Leslie Jackson [2006, PDF]
REEDS Vol 10: Instrumentation and Control Systems - THOMAS D MORTON [2013, PDF]
REEDS Vol 5: Ship Construction for Marine Engineers - Paul A. Russell, E A Stokoe [2022, EPUB]
REEDS Vol 8: General Engineering Knowledge for Marine Engineers - Paul Anthony Russell [2013, PDF]
REEDS Vol 5: Ship Construction for Marine Engineers - Paul A. Russell, E A Stokoe [2022, PDF]
REEDS Vol 2: Applied Mechanics for Marine Engineers - Paul A. Russell [2022, PDF]
The time now is: Today 14:36
