janataly ®   27-Dec-2013 08:07
1 January 2014: Entry into force of 2012 May SOLAS amendments
Amendments to the following:
- SOLAS regulation II-1/8-1, to introduce a mandatory requirement for new passenger ships for either onboard stability computers or shore-based support, for the purpose of providing operational information to the Master for safe return to port after a flooding casualty;
- SOLAS regulation III/20.11.2 regarding the testing of free-fall lifeboats, to require that the operational testing of free-fall lifeboat release systems shall be performed either by free-fall launch with only the operating crew on board or by a simulated launching;
- SOLAS regulation V/14 on ships' manning, to require Administrations, for every ship, to establish appropriate minimum safe manning levels following a transparent procedure, taking into account the guidance adopted by IMO (Assembly resolution A.1047(27) on Principles of minimum safe manning); and issue an appropriate minimum safe manning document or equivalent as evidence of the minimum safe manning considered necessary;
- SOLAS chapter VI to add a new SOLAS regulation VI/5-2, to prohibit the blending of bulk liquid cargoes during the sea voyage and to prohibit production processes on board ships;
- SOLAS chapter VII to replace regulation 4 on documents, covering transport information relating to the carriage of dangerous goods in packaged form and the container/vehicle packing certificate; and
- SOLAS chapter XI-1 regulation XI-1/2 on enhanced surveys, to make mandatory the International Code on the Enhanced Programme of Inspections during Surveys of Bulk Carriers and Oil Tankers, 2011 (2011 ESP Code, resolution A.1049(27)).
ISM Code and guidelines on implementation of ISM (Electronic Edition) - IMO [2010, PDF]
LR Summary Report for the IMO Maritime Safety Committee One Hundred and Fifth session (MSC 105) -…
Code on Noise Levels on Board Ships with Guide for Noise Survey (2014) - Lloyd’s Register + UK P…
SOLAS Consolidated Edition - IMO [2009, PDF]
ISM Code - INTERNATIONAL SAFETY MANAGEMENT CODE with guidelines for its implementation -…
ESP Code Supplement - IMO [2022, PDF]
Guidelines on the Enhanced Programme of Inspections During Surveys of Bulk Carriers and Oil Tankers…
Casualty Investigation Code - IMO [2008, PDF]
IMO - IMDG Code 2020 Amendment 40-20 Vol 1 & 2 and Supplement - IMO [2020, PDF]
Code of safe practice for ships carrying timber deck cargoes - IMO [2011, PDF]
The time now is: Today 18:52
