Kerrang ®   09-Mar-2018 19:40
Mobile Electrician Pro
Year: 2018
Version: 4.0
Developer: Anatoliy Tarasenko
Platform: Android
64-bit OS compatibility: unknown
System Requirements: 1.6 and up
Localization: multilingual
Crack: Not needed
Description: Basic electrical calculations on your mobile phone.
Additional info: What's New
Find calculation
Updated conductor size by formula
Some calculations have been updated
In "Others" added:
UPS Battery size calculator
UPS Battery runtime calculator
In "Converter" added:
Power Units Conversion
Other modifications and improvements
Bugs fixed.
Description EN
The app includes:
Ohms law for DC.
Ohms law for AC.
L-C Resonance Calculator.
Y-Δ Transformation.
Electrical Energy Calculator.
Current density.
Basic transformer calculations.
Calculate AC circuits
Connection of capacitors.
Capacitive reactance.
Run a 3 phase motor on a single phase.
Capacitive Voltage Divider.
Capacitor Charge / Energy Calculator.
Capacitor alphanumeric markings.
Connection of resistors.
Voltage divider.
LED Resistor.
Decode the color bands resistors.
Encode the color bands resistors.
Wheatstone Bridge Calculator.
Resistor alphanumeric markings.
Conductor Resistance.
Conductor length.
Conductor cross section (by the formula).
Voltage drop.
Electrical resistivity and conductivity.
Inductive reactance cable.
Maximum length of conductor.
Calculation Amps motor.
Calculation power motor.
Calculation kVa (3 Phase) motor.
Calculation Power Factor(3 Phase).
Calculation efficiency.
Calculation of the motor slip.
Calculation motor torque.
Individual compensation three-phase induction motors.
Calculation motor power for centrifugal pump.
Calculation motor power for piston compressor.
Calculation motor power for the fan.
Three-Phase Motor Voltage Unbalance.
Three-Phase Motor Current Unbalance.
Allowable ampacities for wire (PUE - Rules of electrical facilitiesmaintenance).
Wire Size Calculator (PUE).
Motor protection.(PUE).
Maximum circuit conductor length.(PUE).
Maximum circuit ampacity.(PUE).
Allowable ampacities for wire (National Electrical Code).
Wire Size Calculator (NEC).
Conduit fill calculator (NEC).
Maximum circuit conductor length.(NEC).
Maximum circuit ampacity.(NEC).
Allowable ampacities for wire (Canadian Electrical Code).
Wire Size Calculator (CEC).
Maximum circuit conductor length (CEC).
Maximum circuit ampacity (CEC).
Allowable ampacities for wire IEC 60364-5-52 (InternationalElectrotechnical Commission).
Wire Size Calculator (IEC).
Maximum circuit conductor length (IEC).
Maximum circuit ampacity (IEC).
Minimum levels of short-circuit current.
Calculate fuse.
Leakage current.
Heating Element use Nichrome.
Calculation sizing a generator for your home.
Calculation of electrical loads applying demand factor
Calculate number cables that fits in a pipe.
IP Code.
Cable Reel Capacity.
Length of cable on a reel.
Calculate cable conductor weight
Cable weight by formulas
Wiring Color Codes
Length of a Hanging Cable
Power losses in cable
Appliance classes
Short-circuit current at the secondary terminals of a MV/LVdistribution transformer
Power of heating element
Force of an Electromagnet
Conversion wire size.
Conversion: Active power - Real power - Reactive power.
Calculation Reactive Power Compensation.
Translations AWG (American Wire gauge) in inches, millimeters,millimeters square and back.
Conversion cos(φ)-sin(φ)-tg(φ).
Conversion of units of temperature.
Conversion of units of distance.
Conversion of units of pressure.
Conversion units of flow.
Conversion units of volume.
Conversion voltage(Peak - RMS-..)
Conversion units of energy.
Conversion SI prefixes.
Converter weight
Time Units Conversion
Electricity Cost Calculator
Widgets for quick access to calculations
Print
Mathematical calculator
Percentage calculator
Online and offline handbook (NEC 2011, PUE Ukraine, PUE Russia ,andmore..).
Online and Offline Search in the handbook.
Save the result of some calculation in HTML format, and then viewand send.
For each calculation is given a separate help.
Dark and light themes application.
Description RU
Возможности приложения:
Закон Ома для постоянного тока
Закон Ома для переменного тока
Расчет RLC - резонанса
Y-Δ Преобразование
Работа электрического тока
Плотность электрического тока
Расчет обмоток трансформатора
Цепь переменного тока
Общую емкость при соединении конденсаторов.
Сопротивление емкости переменному току.
Расчет конденсаторов для пуска трехфазного двигателя в однофазной сети.
Емкостной делитель напряжения.
Заряд и энергию конденсатора.
Буквенно-цифровая маркировка конденсаторов.
Общее сопротивление при соединении резисторов.
Расчет делителя напряжения.
Расчет резистора для светодиода.
Декодирование цветовой маркировки резистора.
Цветовое кодирование резистора.
Мост Уитстона.
Буквенно-цифровая маркировка резисторов
Сопротивление проводника.
Длина проводника.
Сечение проводника (по формуле).
Падение напряжения в цепи.
Удельное сопротивление и проводимость
Индуктивное сопротивление кабеля.
Максимальная длина проводника.
Расчет тока электродвигателя.
Расчет мощности электродвигателя.
Расчет полной мощности электродвигателя.
Расчет коэффициента мощности(3 фазы).
Расчет Кпд электродвигателя.
Расчет скольжения электродвигателя.
Расчет крутящего момента.
Единичная компенсация мощности трехфазного электродвигателя.
Мощность электродвигателя для центробежного насоса.
Мощность электродвигателя для поршневого компрессора.
Мощность электродвигателя для вентилятора.
Расчет асимметрии напряжений трехфазного электродвигателя.
Расчет асимметрии токов трехфазного электродвигателя.
Допустимый длительный ток (ПУЭ, NEC ,CEC ,МЭК)
Сечение провода (ПУЭ, NEC ,CEC ,МЭК)
Расчет сечения кабеля и автомата защиты для подключения электродвигателя.(ПУЭ)
Максимальную длину электрической цепи (ПУЭ, NEC ,CEC ,МЭК)
Максимальную нагрузку цепи (ПУЭ, NEC ,CEC ,МЭК)
Заполнение трубопровода (NEC)
Предохранитель и провод(жучок) для замены перегоревшей плавкой вставки
Минимальный ожидаемый ток короткого замыкания
Суммарный ток утечки для определения дифференциального отключающего тока УЗО
Электронагревательный элемент из нихромовой проволоки
Расчет электрических нагрузок методом коэффициента спроса
Расчет количества кабелей которые помещаются в трубу
IP (степень защиты оболочки)
Емкость кабельного барабана
Расчет остатка кабеля на барабане
Расчет веса металла в кабеле
Расчет веса кабеля по формулам
Цветовая кодировка проводов
Длина кабеля с учетом провиса
Потери мощности в кабеле
Классы защиты от поражения электрическим током
Ток короткого замыкания на вторичных выводах распределительного трансформатора
Мощность ТЭНа
Сила электромагнита
Расчет емкости батарей ИБП
Расчет времени работы ИБП
Конвертер сечения проводов.
Преобразование: Активная - Полная - Реактивная мощность
Расчет компенсации реактивной мощности
Перевод AWG
Преобразование cos(φ)-sin(φ)-tg(φ)
Конвертер температур
Конвертер длины
Конвертер единиц давления
Конвертер единиц производительности
Конвертер единиц объема
Конвертер напряжений синусоидального сигнала
Конвертер единиц электрической энергии
Преобразование приставок СИ
Конвертер единиц веса
Конвертер единиц времени
Конвертер единиц мощности
Виджет
Печать
Расчет мощности генератора для дома
Стоимость электроэнергии
Математический калькулятор
Расчет процентов
Онлайн и оффлайн справочник
Поиск в справочниках
Возможность сохранения результата некоторых расчетов в HTML формате
По каждому расчету дана отдельная справка
Темная и светлая темы приложения
Mobile Electrician Pro v4.0.apk
ElectroDroid Pro v4.5 build 4501 v.4.5 build 4501 - IODEMA Srl [2018] [Android]
Teach Yourself Electricity and Electronics - Stan Gibilisco, Simon Monk [2022, PDF]
1A Unit Converter pro v.2.0.3 - Alexander Vollmar [2018] [Android]
Electrical Engineering for Non-Electrical Engineers, 3rd Edition - S. Bobby Rauf [2022, PDF]
Replacing Your Boat’s Electrical System - Mike Westin [2012, PDF]
Nautical Almanac v.2.3 - Maksym Skrypkin [2024] [Android]
Basic Electricity for Seafarers - Elstan A. Fernandez [2021, PDF]
Elements of Electrical Engineering - Pruthviraja L, Kumara Swamy [2020, PDF]
Power Transformers - Principles and Application - J.Winders [2002, PDF]
UGLY’S Electrical References - George V. Hart [2014, PDF]
The time now is: Today 09:49
