batd ®   13-Jan-2019 10:36
Replacing Your Boat's Electrical System
Year: 2012
Author: Mike Westin
Pages count: 129
Description: This aim of this book is to provide a highly practical, step-by-step approach to upgrading your boat’s old electrical system – but first of all, I would like to say that I am no expert in 12 V DC electrics in boats.
A couple of years ago I started upgrading my own boat. As a novice, my approach was to listen to advice, but I didn’t want to read and understand all
the theory behind it – I just wanted to fix my boat’s electrical system without having to be an engineer or a rocket scientist…
If you want to learn all about the theory of electricity, it’s quite easy. There are many weighty tomes as well as numerous articles on the Peukert
coefficient, detailed CE regulation, or what amperes, ohms and volts are all about. I would definitely recommend reading a couple of these books if you
really want to find out about upgrading your onboard electrical system on a more theoretical level before starting your project.
If, on the other hand, you only want to upgrade your boat without having to wade through a sea of theory, I’ll be explaining the somewhat simplified
practical aspects of upgrading your electrical system in this book.
It won’t be entirely without theory and will include some simple mathematical calculations. But I’ll try to keep this aspect to the bare minimum – how to
calculate the required size of the battery bank and how to decide the optimal diameter for your cables are among the tasks where a pocket calculator
may come in handy among the tasks where some calculations will have to be done.
In this book we’ll look at assessing when it’s time to change the electrical system and how to calculate the capacity of the new system. You will also learn how to choose the right batteries, get the best charge, create neat wiring, install solar panels/wind power, and much more – all in a simple, step-by step approach.
Download [14 KB]
Arcan   13-Jan-2019 11:15
batd, на будущее, делайте пожалуйста скриншоты побольше размером, по крайней мере что то около 1024 х 768 пикселей.
Val Ryman   13-Jan-2019 11:56
Pages 36 and 37 are blank on my copy.
Страницы 36 и 37 не заполнены на моей копии.
batd ®   13-Jan-2019 13:18
Val Ryman, Скачал файл с сайта и проверил. Похоже, проблема только у вас. Попробуйте другой редактор для открытия или перезакачать.
batd ®   13-Jan-2019 13:24
Возможно, запостил не в тот раздел. В Ремонте этому самое место. Модераторы, поможете?
Arcan   13-Jan-2019 13:43
Val Ryman, I can confirm that both pages are readable:
Check your reader or reload torrent.
Upgrading Your Boat’s Interior - Mike Westin [2011, PDF, EPUB]
Replacing your Boat’s Engine - Mike Westin [2012, EPUB]
A Practical Guide to Rudderless Sailing - Hacket A. [2019, PDF]
Essential Boat Electrics - Carry Out Electrical Jobs On Board Properly & Safely - Manley P. [2021, E...
Powerboater’s Guide to Electrical Systems - Edwin Sherman [2007, PDF]
The 12 volt doctor’s practical handbook for the boat’s electric system - Beyn E.J. [1983, PDF]
The Marine Electrical and Electronics Bible - John Payne [1998, PDF]
Sailboat electrics simplified - Don Casey [1999, PDF]
Mobile Solar Power Made Easy! - Mobile 12 volt off grid solar system design and installation - Prows...
Welding Manual Techbook: Go From Beginner To Expert - Nathan Gale [2017, PDF]
The time now is: Today 17:37
