Arcan ®   13-Feb-2018 18:47
JRC Doppler Log Instruction Manual JLN-205Mk2
Year: 2013
Author: JRC
Publisher: JRC
Edition: 1
Pages count: 92
Description: The JRC Model JLN-205MK2 Doppler Log is an equipment for measuring accurately
the true speed and run of a ship, utilizing the Doppler shift of ultrasonic signals, which
are radiated from a trnsducer into sea water downward obliquely to the bow and stern
sides, then scattered and reflected in the sea water. The transducer is mounted on the
hull bottom.
This equipment measures a relative speed to seawater from the hull bottom within 3m.
Therefore, ship’s speed corresponding to the output of a main engine can be obtained
without containing the speed such as the currents. The ship’s speed error margin
caused by the change in the water line doesn't occur because the transmission and the
reception of the pulse are done, and it excludes the signal in the vicinity of the bottom of
a ship. Moreover, because the dual beem method to launch the ultrasonic wave signal in
two directions (fore and aft) is adopted, the ship’s speed error margin because of the
change in the trim is greatly reduced.
This equipment offers measured information to other equipment such as radar and
ECDIS.
JRC Doppler Log JLN-205Mk2
JRC Doppler Sonar Instruction Manual JLN-550 - JRC [2013, PDF]
Furuno Doppler Speed Log DS-80_Operators Manual - Furuno [2003, PDF]
Furuno Doppler Speed Log DS-80_Installation Manual - Furuno [2019, PDF]
JRC Doppler Log JLN-740-741 Instruct Manual - JRC [2019, PDF]
Furuno Operator’s manual Doppler Sonar Model DS-60 - Furuno [2010, PDF]
The Tufmon MEV282…Oil Mist Detector/Manual Instruction [PDF]
Samyung SES-2000 Echo Sounder User Manual - Samyung ENC [2016, PDF]
Marine Online - Radar Plotting and Methods of Plotting [2016, MP4]
The time now is: Today 20:35
