SerTan ®   15-Nov-2017 01:53
Engine Skill
Year: 20XX
Playtime: 24:28
Quality: HDTVRip
Format: AVI
Video: 640x480 / 1334 Kbps / 4:3 / 29 fps
Audio: 128 Kbps / 44 kGz
Description: This DVD has been produced by JSU (Japan Seamen's Union) Welfare Fund Administrative Committee.It is A Guide to Engine Skill and it gives ideas of The Best Seamanship, covers following points:
Lathe - Preparation;
Lathe - Rough machining;
Lathe - Rough machining of cylinders;
Gas welding - Preparation;
Gas welding - Bead practice;
Gas welding - Silver brazing;
Gas welding - Cutting;
Arc welding - Preparation;
Arc welding - String bead;
Arc welding - Weaving bead;
Arc welding - Horizontal-fillet welding.
A Guide to Engine Skills.avi
Download [19 KB]
A Guide to Deck Skills [20XX, AVI]
Practical Welding Skills for Ships [20XX, AVI]
The Best Seamanship (A Guide to Engine Skills) - International Mariners Management Association of…
Guidelines for welding and cutting - BOC [2012, PDF]
Code of Practice 7, The Safe Use of Oxy-Fuel Gas Equipment (Individual Portable or Mobile Cylinder…
A Guide to Ship Handling (The best seamanship) - Japan Captains’ Association (JCA) [2009, PDF]
TIG Welding Entry Level [2023, MP4]
Maintenance & Inspection of Mitsubishi UEC-LS Diesel Engine [20XX, MPG]
Welding: Principles and Practices - Edward R. Bohnart [2017, PDF]
Code Of Practice 5, The Design and Construction of Manifolds using Acetylene Gas from 1.5 to 25…
The time now is: Today 21:04
