maritimer ®   20-May-2020 15:32
Guidelines for Hazardous Area Classification and Electrical Installations of Tankers, 2010
Year: 2010
Author: CCS
Publisher: CCS
Edition: 2010
Pages count: 38
Description: 1.1.1 The Guidelines applies to tankers carrying flammable liquid cargoes in bulk.
1.1.2 The Guidelines is used by the designers, ship builders and surveyors of tankers for reference,
and it does not change the relevant requirements of CCS rules and IEC publications in force.
1.1.3 The term “flammable” referred to in the Guidelines includes:
(1) hazard results determined by the flashpoint, boiling point, flammability and spontaneous
ignition temperature of the cargo carried;
(2) hazard results from the reaction of the cargo with other materials.
Guidelines for Hazardous Area and Equipment of Electrical Installations on Board ChemicalOil Tankers, 2010.pdf
Download [1 KB]
Arcan   20-May-2020 15:38
maritimer, Just the same problem as here - no any seeder and no anyone can download your release.
maritimer ®   20-May-2020 16:20
Arcan, dear sir, is it still not checked? I downloaded my torrent and added by torrent again
Arcan   20-May-2020 16:28
maritimer, Registered: 53 minutes | Completed: 0 times
Seeder not seen: Never
Release get status checked if at least one seeder exist (releaser). If there are no seeder has been seen - release can't be considered as checked.
Arcan   20-May-2020 16:33
maritimer, If you open "DL-List and Torrent activity" - you will see maritimer as a leecher. It mean that you added to client the torrent file which has been sent to site , but not those, which has been downloaded from site. They are different.
Arcan   20-May-2020 17:43
maritimer, Seeder not seen: Never
maritimer left the leechers , but did not reach seeders
Arcan   20-May-2020 18:05
maritimer, BTW, What is correct name of your book? Is it the same as on the poster or in the header?
Arcan   21-May-2020 07:20
maritimer, Just keep in mind that name of release should be the same as name of book.
Fixed.
Inert gas systems: The use of inert gas for the carriage of flammable oil cargoes - Oil Companies…
Rules of Korean Register of Shipping - KR [2018, PDF]
Master’s Guide to Carriage of Seed Cake - Standard Club [2021, PDF]
Rules for Construction and Equipment of Ships Carrying Dangerous Liquid Chemicals in Bulk, 2016 -…
Double Hull Oil Tankers - Guide for Survey, Assessment and Repair of Hull Structures - IACS [2007,…
Rules for Construction and Equipment of Ships Carrying Liquefied Gases in Bulk 2018 - CCS [2018,…
ABS - Rules for Building and Classing - Single Point Moorings - ABS [2022, PDF]
Rules for Bulk Carriers and Oil Tanker - Indian Register of Shipping [2023, PDF]
Chemical Tanker Tank-Cleaning - Navios Tanque [2011, PDF]
The time now is: Today 16:01
