Nemo ®   07-Dec-2016 20:05
Inert Gas Systems
Year: 1990
Author: IMO
Genre: Technical book
Publisher: IMO
Edition: 3
ISBN: 978-92-801-1262-7
Pages count: 95
Description: This publication contains the text of guidelines for inert gas systems and relevant IMO documents on inert gas systems and supersedes the publication 860 83.1S.E. Provisions of the SOLAS Convention covering application and technical requirements for inert gas systems, together with recent developments on regulations for inert gas systems on chemical tankers are included with a view to setting out the framework as well as details of international requirements for inert gas systems. Part I: Guidelines for Inert Gas Systems
The International Conference on Tanker Safety and Pollution Prevention, 1978, with resolution 5, requested the Organization to re-examine the requirements relating to inert gas systems in regulation II-2/62 of the 1974 SOLAS Convention, and to develop guidelines to supplement the requirements of that regulation. 3 The Maritime Safety Committee at its forty-second session approved the Guidelines for Inert Gas Systems (MSC/Circ.282), and at its forty-eighth session adopted amendments to sections 8 and 12 of the Guidelines (MSC/Circ.353). Furthermore, the Maritime Safety Committee at its fiftieth session adopted revised section 5.5 - cargo discharge - of the revised Guidelines (MSC/Circ.387). This part provides the text of the Guidelines for Inert Gas Systems which incorporates all these amendments. Part II: Provisions of application 4 Provisions of application for inert gas systems in the 1974 SOLAS Convention were modified by the 1978 SOLAS Protocol and amended by the 1981 and 1983 amendments. This part contains all the relevant provisions of application as well as clarification of application of inert gas system requirements developed by the Maritime Safety Committee at its fifty-fifth session (MSC/Circ.485). Part III: Provisions of technical requirements
Technical requirements for inert gas systems in the 1974 SOLAS Convention were amended substantially by the 1981 amendments and to a lesser extent by the 1983 amendments. These technical requirements which are to be applied under the provisions of the SOLAS Convention are contained in this part. Part IV: Regulations for inert gas systems on chemical tankers 6 Regulation II-2/60 of the 1978 SOLAS Protocol requires new and existing chemical tankers of a certain size, when carrying petroleum products, to be fitted with a fixed inert gas system at specific dates. The Assembly at its twelfth session, recognizing the unique features of chemical tankers, adopted the Interim regulation iii for inert gas systems on chemical tankers carrying petroleum products (resolution A.473(XII)), and urged Governments concerned, under the provisions of regulation 1/5 of the 1974 SOLAS Convention, to apply to chemical tankers as appropriate the Interim regulation as equivalent to regulation II-2/62 of the 1974 SOLAS Convention. 7 The Assembly at its fourteenth session, recognizing that the extension of the regulation in resolution A.473(XH) to cover the carriage of petroleum and other liquid products would be desirable, adopted resolution A.567(14), the regulation for inert gas systems on chemical tankers, which supersedes resolution A.473(XII). 8 The Assembly at its fourteenth session also adopted draft amendments to regulation H-2/55.5 of the International Convention for the Safety of Life at Sea, 1974, as amended (resolution A.566(14)). These amendments were subsequently adopted by the Maritime Safety Committee at its fifty-seventh session and included in the 1989 set of amendments to the SOLAS Convention expected to enter into force on 1 February 1992 and the resolution is also contained in this part. Part V: Application of requirements for inert gas
CONTENTS
Page
Foreword iii
PART I Guidelines for Inert Gas Systems l
(MSC/Circ.282 as amended by MSC/Circ.353 and
MSC/Circ.387) 1
PART II Provisions of Application 50
1 1974 SOLAS Convention 50
2 1978 SOLAS Protocol 54
3 1981 Amendments to the 1974 SOLAS Convention 58
4 1983 Amendments to the 1974 SOLAS Convention 63
5 Clarification of inert gas system requirements
under SOLAS 1974, as amended (MSC/Circ.485) 65
PART III Provisions of Technical Requirements 66
1 1974 SOLAS Convention 66
2 1981 Amendments to the 1974 SOLAS Convention 68
3 1983 Amendments to the 1974 SOLAS Convention 75
PART IV Regulations for Inert Gas Systems on
Chemical Tankers 76
1 Regulation for inert gas systems on chemical tankers
(resolution A.567(14)) 76
2 Draft amendment to regulation H-2/55.5 of the
1974, as amended (resolution A.566(14)) 84
PART V Application of Requirements for Inert Gas
Systems for Oil Tankers by Port Authorities and
Terminal Operators (MSC/Circ.329) 87
sumityad1509   05-Aug-2018 09:33
Thank you so much . Earlier i tried downloading this same torrent but there was a copyright strike .
Системы Инертного Газа (Руководство по безопасному применению инертного топочного газа) / Inert Gas ...
Crude Oil Washing Systems - IMO [2000, PDF]
Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk (BCH Code) - I...
Resolutions: MEPC.314(74); MEPC.316(74); MEPC.317(74) – MARPOL amendments - IMO MEPC [2019, PDF]
Tanker Safety Guide (Chemicals) - International Chamber of Shipping [2014, PDF]
POLAR Code (The International Code for Ships Operating in Polar Waters) - KS Gill [2016, PDF]
ISM Code - INTERNATIONAL SAFETY MANAGEMENT CODE with guidelines for its implementation - Internation...
Revised Port State Control (PSC) Procedures - IMO [2023, PDF]
  • Topic closed
The time now is: Today 02:58
