janataly ®   10-Mar-2013 22:17
ClearWater Cargo Assistant/II (R) Ship Loading Program In-house training
Year: 2009
Version: 1
Description: ClearWater, also known as the Cargo Assistant, is the universal cargo handling software that is aimed to assist in container vessels loading. The Cargo Assistant main window is the starting point for all services available. It is build by the main menu and the results line close to the bottom frame which contains the most important calculated results for draft, stability and longitudinal strength. The data displayed at the results line can be changed. For that purpose move the mouse over it, right mouse button click to open a popup menu and choose the menu item of your choice. Further you will find at the left side of the result line two leds. The upper indicates the calculations of draft, stability and longitudinal strength running while blinking and the lower indicates calculations of lashing forces running while blinking.
ClearWater.zip
Alfa Laval S-Type separatots / General Service Instructions [HTML]
COLOS (Computer-Loading-System) v.1.0.1 [2002]
PrimeShip SteelCoilLoading Program v.3.23 - ClassNK [20??]
LoadPlus - Loading computer application for 8300 DWT Oil/Chemical Tanker v.1.0.0 build 2347 - HANLA…
Ship Manager 88 v.4.52.2.14 - Loading program for 13000 DWT Oil/Chem Tanker - Techmarine Co. Ltd…
LNG Cargo Simulator v.1.00 [2007]
MACS3 Training Course for Container Vessels v.1.1.29.84 - NAVIS [2020]
Mariners Office v.5.1.0.0 - Maritime Software [2008]
LoadCom - Loading program for 16000 DWT Oil/Chem Tanker v.1.5 - Shin Kurushima Dockyard Co., Ltd…
WinCASP ships profiles - CASP [2001]
The time now is: Today 16:48
