Guest   30-Nov-2023 16:26
4logo4, спасибо это для про или обычной ? Или без разницы?
AlexArctic   02-Dec-2023 12:32
Дайте пожалуйста код к карте (для про версии) SDVJRSM203MAP23.dbv , Please have anyone code (pro ver.)? Thanks
Mbungurz   12-Dec-2023 05:17
My timezero keep delete PBG point after some time, depth contour on my PBG in 3D map always back to basic too, until now i can't find what's wrong in PBG setting, backup PBG and restore won't show the depth result from my pbg... Please help if anyone's have same issue and managed to solve it
Craztool   12-Dec-2023 10:05
Всем привет. Поделитесь, пожалуйста, картами Японского и Охотского моря. Благодарю за ранее | Hey, everybody. Please share maps of the Sea of Japan and Sea of Okhotsk. Thank you.
johncoltrane472   14-Dec-2023 13:03
Hi,
I've followed carefully all the steps, used the patches, block host etc.
I can see the urls in the host file.
However it works fine when the Internet connection is down, but as soon as I turned it on, and start the application, it shows me the screen asking for the S/N again and fails to proceed.
How do I fix this? clearly it is still reaching some license server.
thanks!
johncoltrane472   15-Dec-2023 14:11
johncoltrane472,
I reply to myself. The problem is SOLVED.
It was not the activation, but accessing the remote PC via Remote Desktop.
If one uses RDP and launches TZ, it will not start throwing an error "Network not allowed".
But from the PC itself directly, it starts 100% fine.
johncoltrane472   15-Dec-2023 14:14
matrixdu,
This tool is always quaratined by the antivirus reporting a Trojan inside.
Even trying an only scan, two AVs report a malware issue.
I opened it into a Windows Sandbox, however every time you do that you have to re-download the updates and lose all the settings.
It could be a False Positive, but I am not ok to risk it
The time now is: Today 17:19
