My timezero keep delete PBG point after some time, depth contour on my PBG in 3D map always back to basic too, until now i can't find what's wrong in PBG setting, backup PBG and restore won't show the depth result from my pbg... Please help if anyone's have same issue and managed to solve it
Всем привет. Поделитесь, пожалуйста, картами Японского и Охотского моря. Благодарю за ранее | Hey, everybody. Please share maps of the Sea of Japan and Sea of Okhotsk. Thank you.
Hi, I've followed carefully all the steps, used the patches, block host etc. I can see the urls in the host file. However it works fine when the Internet connection is down, but as soon as I turned it on, and start the application, it shows me the screen asking for the S/N again and fails to proceed. How do I fix this? clearly it is still reaching some license server. thanks!
johncoltrane472, I reply to myself. The problem is SOLVED. It was not the activation, but accessing the remote PC via Remote Desktop. If one uses RDP and launches TZ, it will not start throwing an error "Network not allowed". But from the PC itself directly, it starts 100% fine.
matrixdu, This tool is always quaratined by the antivirus reporting a Trojan inside. Even trying an only scan, two AVs report a malware issue. I opened it into a Windows Sandbox, however every time you do that you have to re-download the updates and lose all the settings. It could be a False Positive, but I am not ok to risk it
C:\ProgramData\TimeZero\Data ==> File Tracks2.tzdb
https://mega.nz/file/y2pTRJQJ#I...zCBoFpW7ywFq6Xbg
Note: I made this database last year, Many vessels are missing.
thanks!
UC: C6AF7914655CE60E268E
