matrixdu   09-Mar-2025 19:26
Domingo,
If problems with activating TZ (error ac ) do this ;
delete license file at C:\Program Data\CrypKey\Licenses folder and , also you need to delete serial_number file at folder C:\ProgramData\TimeZero\MetaCatalog
When you are done with that begin with all the activation process again or
uninstall TZ v4 delete C:\ProgramData\CrypKey\Licensesdelete C:\ProgramData\TimeZero RESTART computer kill process crp32002.ngn if running reinstall TZ V4 with a new serial number or
    1 - close Timezero
    2 - open task manager and kill all the task running named crp320002.ngn
    3 - delete folder C:\ProgramData\CrypKey\Licenses
    4 - remove the serial number file in programdata/timezero/metacatalog
    5 - Deactivate your internet connection
    6 - launch again Τimezero and try again the activation.
    7 - reactivate TZ with a new serial number and you should be back in business.
Domingo   11-Mar-2025 15:28
matrixdu, First of all, thank you. I had the hidden folder option, that's why I didn't understand the process to get to it. Well, I deleted the two folders, metaCatalog and licenses. I have uninstalled the TZ program, I also deleted all the crp320002.ngn tasks, well, I'm going to reinstall everything. I hope it works. Thanks.
Domingo   11-Mar-2025 18:09
Hello, I reinstalled everything after following all your instructions and everything went perfectly. Now I have the SDVJEWM228MAP25.dbv card inside the program. I have to install the program again to be able to enter the CU key. If anyone has the link to download the program, I would appreciate it. Thanks again, I am very grateful.
The time now is: Today 02:37
