Hajjouz   09-Oct-2023 03:30
Thank you
Already I Installed it on my Laptop,But now I'm trying to install it to my friend it keeps Asking for Active every time I run it .
Best regards.
packitup   09-Oct-2023 16:10
Good day, thank you for sharing this! I am having problems downloading charts, TZ website asks for a serial number to download the charts.
Thanks
matrixdu   02-Nov-2023 14:55
Hajjouz, If problems with activating TZ (error ac ) do this
delete de license file at C:\Program Data\CrypKey\Licenses folder and , also you need to delete serial_number file at folder C:\ProgramData\TimeZero\MetaCatalog
When you are done with that begin with all the activation process again
or
uninstall TZ v4
delete C:\ProgramData\CrypKey\Licenses
delete C:\ProgramData\TimeZero
RESTART computer
kill process crp32002.ngn if running
reinstall TZ V4.1.0.53 with a new serial number
or
1 - close Timezero
2 - open task manager and kill all the task running named crp320002.ngn
3 - delete folder C:\ProgramData\CrypKey\Licenses
4 - remove the serial number file in programdata/timezero/metacatalog
5 - Deactivate your internet connection
6 - launch again Τimezero and try again the activation.
7 - reactivate TZ with a new serial number and you should be back in business.
kadoka   20-Nov-2023 22:22
Hello
When I try to update charts catalogue by Map manager 2.7.1 then still I have "0" update and the last vector charts are from May 2023.I wonder if there is newer.
Best regards
HAISEAMEN   23-Nov-2023 17:58
Hi again, after installation, everything worked fine, but when I turned on the Internet and restarted the program, I have such a problem
Domingo   24-Nov-2023 03:25
tomado, intento descargarlo pero no me descarga, no lo guarda en mi gun archivo el gráfico .no se como configurarlo,algo no sale mal.si lo pasó al TZ se bloquea pudiendo clable UM ,no la reconoce.
Domingo   24-Nov-2023 03:26
tomado, taken, I try to download it but it doesn't download, it doesn't save the graph in my gun file. I don't know how to configure it, something doesn't go wrong. If I passed it to the TZ it crashes and can be clicked on UM, it doesn't recognize it .
Domingo   24-Nov-2023 03:29
HAISEAMEN   24-Nov-2023 07:09
Rig_Mover   25-Nov-2023 08:09
Hello,
I have just installed TZ Navigator 5.0.0.56 and it seems to be running fine. Is there any updated MapManager that will work with this version or another way to generate the UC's for the charts in this version?
Thank You for your time in advance.
Rig_Mover   25-Nov-2023 20:45
zuburki, It was a retail version with Ser.No. and Activation code. The UC's generated from Map Manager or the MaxLicV4Nav keygen would not unlock the charts I am trying to install.
SDVJAFM210MAP23.dbv
SDVJEWM228MAP25.dbv
SDVJEMM112MAP26.dbv
Any help would be appreciated.
The time now is: Today 01:46
