D_E_A   23-Feb-2023 18:52
90207D_E_A, Obviously I tested both things. I would like to know why I can't download Premium weather and why I can't interface any radar with this version.
I found a way to download the normal weather of Timezero 4 (but not Premium) without the program showing the crack screen and staying connected to the Cloud, synchronized in real time with the Cloud working, despite not being an original version.
But I can't unlock the premium.
You should change the blocked IPs because the ones in the .bat file are not good.
Also I was told by important people at Furuno dealing with Timezero, that it is not possible to interface the Radar with a cracked Timezero, is this true?
I asked because I would like to understand if other people are capable of it.
Я думаю люди качают эту взломанную версию для личного пользования на личный ноутбук (как я), поэтому подключение к радару не нужно, а погоду в программе можно через zyGrib смотреть. Лично мне нужно чтобы эта программа показывала карту, местоположение и AIS, остальные функции для личного пользования мне не нужны.
tomado ®   23-Feb-2023 21:42
capellidipaglia, Good day ,
Is the Radar module enabled on your TZ ?
You just need to do the following steps:
- in Option > Initial setup > Advanced > select "generic" radar and quit/relaunch
- the radar doesn't work but the radar workspace and ribbon menu appear…
- a. create a new custom workspace with for example Nav and Radar
- b. in the Navigation workspace, use the ribbon to select "radar overlay"
- go back in Option > Initial setup > Advanced > select your radar and quit/relaunch
- the custom workspace still displays the radar and a way to manage it
- the navigation workspace displays the overlay when the radar is on Tx
capellidipaglia   23-Feb-2023 22:08
90213capellidipaglia, Good day ,
Absolutely yes, I have every module possible. Like the picture you showed.
https://i.postimg.cc/tCXnyvK6/Cattura2.jpg
But as I show you in this image, I don't see any symbols that refer to how to access the radar mode.
https://i.postimg.cc/W4K01mGv/Cattura.jpg
omar.ronaldo9   23-Feb-2023 22:23
tomado,
Thanh u
I get un code
I have a question
After install the program and install charts
Any problem if connect internet to laptop?
شكرا
FUCKINGHELL   23-Feb-2023 23:02
capellidipaglia, as far as I know... radar works without any problems. Weather does not with publicly available crack, but some use fully cracked version privately. Next time you talk with "important people at Furuno dealing with Timezero", tell them to go fu*** their mothers.
capellidipaglia   23-Feb-2023 23:10
tomado,
I saw your reply now, sorry. I thank you infinitely. Can I ask one more thing?
How do you manage to interface a radar to a pc with Timezero?
Do you need a router or is a rj45 crossover cable enough?
Is there a series of specific settings to be made on the pc and Timezero? (beyond assigning a static IP)
I'd like to understand why every technician I've talked to seems to have very different opinions (many turned out to be false) so that he can compare my method to improve.
FUCKINGHELL,
I understand you. About a year ago I spoke to an important person at Furuno about the problems that version 4 of Timezero has, regarding the inability to download the weather with a satellite connection. Initially they didn't take me seriously, I had to spend afternoons collecting evidence. He brings everything to the producers of the program in France. Some time later he told me that I was right, they created version 4 without thinking about it and changed all the servers. You can only download from the satellite with version 3. Some time later, version 4.1 came out which introduced the possibility of downloading the weather with satellite.
Too bad they haven't really solved the problem and it sucks
FUCKINGHELL   23-Feb-2023 23:20
capellidipaglia, downloading the weather with satellite is the smallest problem they have :) From my understanding the core code of TZ is just the same old MaxSea plus many useless crap and nicer user interface. On my side I can't use TZ at all on older laptop, just because it is using 50-60% of CPU power in idle mode. This is crazy.
P.S. they never solved any problems in the past, nor they will solve in a future. There is no way to change mentalité or it simply too expensive to change something (in many case this means writing new code from zero).
capellidipaglia   23-Feb-2023 23:29
FUCKINGHELL,
I quite agree. Unfortunately the weather problem for all my customers is practically the only reason to buy Timezero. They don't care about cartography, radar, nothing, they just want to spend thousands of euros just to be able to have weather that isn't low quality like the free Gribs.
FUCKINGHELL   24-Feb-2023 12:50
capellidipaglia, TZ weather display is a total crap, one must be schizophrenic to use such coloring and all these directional moving arrows. Nice for a minute or two, but using it for longer time in a real conditions at sea... This is probably designed by office marketing boys for infants and blond ladies, not professionals. As you probably know, weather is as accurate as grib model is, plus resolution. TZ buys grib data from providers and this is it. There are free options, there are payed options to obtain good quality gribs and just feed them into cracked TZ. Wasting thousands of euro for this... well whole world full of idiots with full pockets of $$$.
tomado ®   24-Feb-2023 14:05
capellidipaglia, Good day,
If the customers want accurate weather forecast software, suggest them StormGeo products that are used in the maritime industry.
TimeZero should mainly be used for navigation only not for Weather routing.
Have a nice day.
skitaletc-1963   25-Feb-2023 05:15
lapadu,
Добрый день Господа!!!! Всем здрасьте. Во-первых, большое спасибо за файл. TZ v4 Nav. на Win 11 64 все работает прекрасно, на подключённом нэте кряк не сбрасывает, НО, при перезапуске ТЗ почему-то сбрасывается UM и все установленные карты, кроме программных. Хотелось бы узнать, почему? Ну и при повторном вводе карт при перезапуске программы все равно слетают карты. Господа, нужна помощь в этом вопросе.
FUCKINGHELL   25-Feb-2023 11:53
skitaletc-1963, сброс видимо из-за отсутствия прав доступа к фолдеру C:\ProgramData\TimeZeroREC\MetaCatalog с файлами serial_number и ucpool или же вы не использовали батники блокировки через фаервол или хосты. Копать в том направлении. Все батники будут работать и на Про. Можете спросить автора methive https://www.gpspower.net/members/methive-1625178.html на другом форуме где лежaт оригиналы. Там найдете 3 батника.
| | | | | | WORK-AROUND: TIMEZERO PRO&NAV UM CHECK BLOCK VIA HOSTS | | | | | |
| | | | | | WORK-AROUND: TIMEZERO PRO&NAV UM CHECK BLOCK VIA FIREWALL | | | | | |
| | | | | | WORK-AROUND: TIMEZERO PRO&NAV CRACKED SCREEN | | | | | |
lapadu   25-Feb-2023 14:27
FUCKINGHELL, dozens of uc for charts are published here but I can not see that anybody thanks anyone (thanks to the exceptions), these uc are also produced by somebody don't they?
kava   25-Feb-2023 15:04
Подскажите как включить полноэкранный режим .
Заранее благодарен за ответ .
The time now is: Today 21:58
