lapadu   28-Jan-2023 19:36
digiclic, of course, you can find if you use excel file or map manager..................
2143D127D82D638B25A2
kryks11   30-Jan-2023 14:01
lapadu, Sorry, how did you find SDVJEMM112MAP25.dbv in Map Manager? Map Manager I found SDVJEMM112MAP24, EXCEL: SDVJEMM112MAP20 ...
tomado ®   30-Jan-2023 15:53
kryks11,
Good day,
First, check if you have got Map Manager 2.6.0.0.
go to functions ===> check for new map updates on web. and let it make the latest update.
go to select chart ==> Map file Name and do a search for your chart (SDVJEMM112MAP25.dbv) you will find the UC CODE and all the information related to the chart.
7
kryks11   01-Feb-2023 15:33
Hi again, after installation, everything worked fine, but when I turned on the Internet and restarted the program, I have such a problem ..
lapadu   01-Feb-2023 17:15
kryks11, delete following ;
C:\Users\yourusername\Documents\Temp\{aaa3e21c64-63sdf25-1654e-zg1-0856410318}
C:\Users\yourusername\AppData\Roaming\Temp\{6f3e96c64-64f325-12ce-bhc1-08102bf10318}
C:\ProgramData\CrypKey\{4d36e96c-e325-11ce-bfc1-08002be10319}
C:\Users\yourusername\AppData\Local\Temp\{5e3e96c-e325-11ce-bfc1-08002be10319}
C:\ProgramData\Temp\{8f3e21c64-63f325-12ce-z5g1-081999f10318}
skitaletc-1963   03-Feb-2023 13:13
Всем привет!!!! Ребята, кто знает или подскажите, как можно ввести корректуру " Admiralty Vector Chart Service" и "Admiralty Vector Chart Service" в TimeZero Pro v.4???
MiguelAC   08-Feb-2023 14:12
hi everyone! I just installed MapManager and done the steps, but it doesn't show me any kind of data when I do the search... do I need to install ucpool or something more? thanx
The time now is: Today 08:00
