Edwin ®   04-May-2020 13:45
Grain Stability Calc (Spain)
Year: 2020
Developer: Ministerio de Fomento
Localization: spanish/english
Description: Excel spreadsheet to calculate the grain stability as per Spanish regulations and required by the harbourmaster in Spanish ports.
This spreadsheet has been modified in order to calculate the residual dynamic stability and draw the simpson ordinates in the stability curve automatically
CALCULOS GRANOS Nfmto.xls
Download [520 B]
Arcan   04-May-2020 16:16
Edwin, moved back to Calculation soft. Fixed the languages in the header.
Arcan   05-May-2020 10:00
Edwin, do you see that second day no anyone can download your file? 87.7% and that is all. Check your client and torrent file.
Edwin ®   05-May-2020 11:06
Arcan,
I created a new torrent, how do I upload/update this new torrent file
Edwin ®   05-May-2020 11:39
Arcan,
Thank you, can you change the status so I can edit the torrent ?
Arcan   05-May-2020 14:24
Edwin, NO ANYONE SEEDER! Edwin - as leecher!!! therefore nobody can download your file!
Edited: Now I see that Edwin moved to seeders.
Edwin ®   05-May-2020 14:47
Arcan,
Completed 0 times, however there are 3 seeders, how can
Arcan   05-May-2020 14:52
Edwin, "Completed" will be renewed later ( I don't remember, probably once per day)
Reglamento de las radiocomunicaciones marítimas a bordo de los buques civiles españoles -…
A Practical Guide to Damage Stability Assessment - SOLAS Regulation on Damage Stability - J…
Teoría del buque - Antonio Bonilla de la Corte [1979, PDF]
Ship Stability Booklet - Simpson’s Rules - M.Bordbar [20XX, PDF]
AMSA Grain Stability Calculation Forms & more - AMSA [201?, PDF]
PrimeShip SteelCoilLoading Program v.3.23 - ClassNK [20??]
STAR FINDER CALCULATOR excel Windows7,8,10 - vincent [2018]
Excel Draft Survey [2019,XLSX] Draft and Trim calculation - Capt.Leo [2019]
Marine Order 33 (Cargo and cargo handling - Grain), Explanatory Statement & Calculation of…
Teoría del Buque - Cesáreo Díaz Fernández [1972, PDF]
The time now is: Today 16:56
