Gogo81 ®   10-Apr-2020 06:59
Surveying Fiberglass Sailboat A Step-by-Step Guide for Buyers and Owners
Year: 1994
Author: Henry C. Mustin
Publisher: International Marine
Edition: First
ISBN: 978-0070442481
Pages count: 147
Description: Mustin's part-by-part look at hull, deck, rig, and machinery is both a minicourse for transforming used-boat shopping from a game of craps to a science, and the first step in a holistic boat maintenance program. His discussion of the significance of cracks found in aging hulls and decks is the most thorough in print. He is not shy in assessing the lack of regulation of professional surveyors, nor does he shrink from pointing a finger at shoddy building practices.
Having a used boat surveyed is a critical prelude to buying it. Yet a professional survey is expensive--several hundred dollars. Surveying Fiberglass Sailboats will enable you to conduct your own surveys while narrowing the field, then monitor a professional surveyor's performance when selecting your target boat.
Surveying fiberglass sailboats a step-by-step guide for buyers
Download [4 KB]
Sailboat Hull & Deck Repair - Don Casey [1996, PDF]
Inspecting the Aging Sailboat - Casey D. [1997, PDF/EPUB]
Spurr’s Guide to Upgrading Your Cruising Sailboat - Spurr D. [2006, PDF/EPUB]
Don Casey’s Complete Illustrated Sailboat Maintenance Manual: Including Inspecting the Aging…
From A Bare Hull: How To Build A Sailboat - Ferenc Mate [2000, PDF & EPUB]
Boatowner’s Sheet Anchor: a Practical Guide to Fitting Out, Upkeep and Alteration of the Small…
Guide for Surveys Based on Machinery Reliability and Maintenance Techniques - ABS [2016, PDF]
Guide for Surveys Based on Machinery Reliability and Maintenance Techniques - ABS [2023, PDF]
The complete guide to metal boats: building, maintenance, and repair - Roberts-Goodson Bruce [2001,…
General Dry Cargo ships - Guide for surveys, assesment and repair of hull structures - IACS [2016,…
The time now is: Today 16:22
