seamaner008 ®   13-Mar-2020 13:32
SAS.Planet ( SASPlanet )
Year: 2020
Version: 200114.1.107
Developer: sasgis.org
64-bit OS compatibility: unknown
System Requirements: The program does not require installation, unzip the archive to any directory (except Program Files \ or Program Files (x86) \) on your hard disk - the program is ready to work. For the program to work correctly, the following software is required:
Windows 2000 or higher operating system
Recommended Requirements:
CPU: 2.8 GHz
RAM: 1.5 GB
Video card RAM: 128 MB
monitor, keyboard, mouse
Localization: english / russian
Description: Description
SAS.Planet ( SASPlanet ) - a program designed to view and download high-resolution satellite images and conventional maps provided by Google Earth, Google Maps, DigitalGlobe, Kosmosnimki, Yandex.maps, Yahoo! maps to a computer’s hard disk Maps, VirtualEarth, Gurtam, OpenStreetMap, eAtlas, iPhone maps, General Staff maps, etc. All downloaded maps will remain on your computer and you can view them even without an internet connection. In addition to satellite maps, it is possible to work with political, landscape and combined maps, as well as maps of the moon and Mars.
Downloading maps is carried out as the selection of a certain area (possibly non-rectangular), and in the process of moving around the map. Maps are often updated - the program will allow you to download only the newest.
Main functions
In addition to viewing and downloading, the program has the following useful functions:
work with a GPS receiver;
routing;
distance measurement;
display KML files;
support for the Panoramio service;
forming a layer filling map - this function allows you to see areas on the map that you have already loaded into the cache or, conversely, that you do not have;
saving part of the map into one image, which you can view and process in any graphics editor, as well as use in other GIS applications, for example, OziExplorer (for which the program will create a binding file);
You can save places of interest to you and subsequently easily find them, as well as make them always appear on the map;
overview map - it will help you easily find out the location of the place that you are currently viewing, as well as quickly move to any other place on the map;
viewing the map in full screen mode - which is especially convenient with a low screen resolution;
conversion from one layer of all previous ones - will significantly reduce your Internet traffic, for example, you can download your city only on scale 18, and form all the previous ones on its basis;
the ability to export maps to a format supported by iPhone maps;
the ability to export cards to a format supported by mobile Yandex.Cards version 3;
the ability to export raster maps to JNX format, supported by Garmin navigators;
loading and displaying Wikimapia objects;
search for places using Google and Yandex;
adding custom maps.
Sasplanet.zip
Download [23 KB]
cvaigon   13-Mar-2020 20:37
люди ,я таки дико извиняюсь.
но как- подключить с-map.
хочется счастья- много и за даром
а он таки ,проснулся и не хочет.
jwlkr74   31-Mar-2020 18:20
cvaigon,
I've found this solution to add c-map on sasplanet:
- Search c-map.zmp.zip on Google and download it
- unzip in a temp folder
- copy folders:
c-map.zmp
c-map-direct.zmp
into folder:
sasplanet/Maps/sas.plus.maps/_water
restart sasplanet and the two new menu about c-map appear on "marine map" section.
Hoping it's useful for you.
Regards.
cvaigon   03-Apr-2020 19:11
thanks a lot. for your help.
but still, it doesn’t work.
gives an error code 403.
You can send your- sas planets.
  without cache.
that is, the basic version, from your computer or give a link.
may help.
  thanks.
possible in private messages.
cvaigon   06-Oct-2024 09:32
РЕЧНЫЕ КАРТЫ ЗДЕСЬ.
https://www.c-map.com/chartexplorer/
СОНАРНАЯ СЪЕМКА ПЛАНЕТЫ РЕК, МОРЕЙ , ОЗЕР И ОКЕАНОВ
СЪЕМКА НА ТЮМЕНСКОМ РЕЙДЕ. СОНАР.+СУРГУТСКИЙ 2 МОСТ КОТОРЫЙ СТРОЯТ.+знаменитые места России
Вопрос .
Как прикрутить все это в SAS PLANET, чтобы выгружать растры и обойти при этом закрытые участки рек и водоемов на сайте (это не наша цензура , это их цензура).
Есть идеи?????
Образцы прилагю.
Извиняюсь за размер шрифта-больные глаза.
IACS Blue Book - IACS [2018, PDF]
Loadstar v.1.0 - IBM [2008]
ChartBrowser v.2.4.6.8 - ChartWorld [2018]
IACS Blue Book - IACS [2020, PDF]
IACS Blue Book - IACS [2019, PDF]
User’s Guide PMI System (On-line) Pressure Analyser Version 2.0 - MAN B&W Diesel A/S [2001, PDF]
MarEng Learning Tool Plus [HTML version] [2007]
Maris ECDIS900 Operator Manual - Navico Holding AS [2017, PDF]
JRC JAN-701B/JAN-901B (Instruction Manual) - Japan Radio Company [2012, PDF]
BOCA Suite v.2.2.0.3 - AVEVA [2018]
The time now is: Today 14:25
