malakes   17-Nov-2019 18:02
installed ok. i can't start it because initial conditions are not being loaded. also volume is 0% from default. i try to load conditions but nothing happens and the software remains in freeze mode.. is there any file to copy or any other way ? i tried reinstall many times with no result..thank you
malakes   17-Nov-2019 18:03
chrysanthos   05-Dec-2019 11:36
question...can i install it to a usb stick so i can make it portable? or its illegal? please answer me cause i had been attacked by ramson ware so i format my pc....
pinkguy   04-Oct-2020 04:53
hi guys i have i'm using k mc90v 2.3.0.0130(00) the first time installed it, it ran smoothly by following all the above mentioned ways and watching installation videos on youtube but I had uninstall the program and the next time when I installed it the simulator is stuck at freeze condition. I have tried multiple times by uninstalling and installing it again and again but the same problem still persist.
Please help me out...
This is the image of the problem:
click me
14qjrv080190   04-Oct-2020 18:09
chrysanthos, it can't be installed in a flash drive since some files are installed in windows system files..just download it..format ur pc and reinstall it again
pinkguy   04-Oct-2020 21:15
14qjrv080190, version 2.5 is working fine, but i wanted to know why this error is showing up cause everything else seems to be fine but its somehow failing to load initial condition and simulator is stuck at freeze condition...
pinkguy   05-Oct-2020 23:09
14qjrv080190,I thought of the same and I deleted the entire norcontrol folder in program files(x86) before re-installing but it still doesn't work.
The time now is: Today 06:30
