aurum ®   17-Aug-2019 09:28
12 Volt Doctors Practical Handbook 1983 Beyn
Year: 1983
Author: Edgar J. Beyn
Genre: Handbook
Number of pages: 233
Description: You may think that making a wiring diagram for your boat wouJd be a
monstrous headache, and the results as useful as a street map of Brooklyn
viewed from ten feet away. But read how simple it is when you take small
steps, one area and one sketch at a. time, whenever you happen to look at
a particular detail. Eventually, you will have a collection of sketches which
is your wiring diagram.
With the diagram, trouble shooting will be much easier, and so will planning.
Repairs will be much faster, too. Sooner or later, you wi" decide that
as designed, the boat's electrical equipment is less than perfect. You may
want lights in new places, switches in different locations, add instruments
and equipment, run electricity from better charged batteries. The step from
knowing your boat's eJectrics to making changes will come quite naturally.
Start with a relatively easy subject and later you will be surprised by the
degree of confidence you have gained. Your boat wlll then fit your personal
expectations in a way no one else can match with any amount of hired
repair service.
As in earlier editions of this book. you are invited to write with questions
and comments which we will answer as swiftly as possible. Especially. tell
us what new details should be covered in the next edition, and what additional
equipment you would like to have or make. And te/l us about your
boat: it enjoys a quality not many others do, your tender loving care.
fntroduction ........ , ........................................................ .
Very Basic Electricity ................. , ...... , ............................. .
Volt. Ohm, Ampere, Watt Calculated ..................................... .
How to Make and Use a Test Light ....................................... .
The Volt Ohm Meter (VOM) ............................................... .
Wiring Diagrams ....... , ...................... , .. ,., .......... , ........ " .. ,
Wire Size Table and Examples ........................................... .
Soldering .............. , ........................................ , ............ .
Finishing Touches ....................................................... , ..
Switch On Heret Off There ................................................ ,
Trouble Shooting .................................................... , ..... .
Electrical Leaks ................................ , ..... , ........... , ......... .
Electrolytic Corrosion ................ , ....................... , ..... , ...... .
iii
9
11
15
17
44
45
51
55
57
67
71
Stray Electric Current Corrosion ......................................... , 103
Lightning., , ...................... , .... , .. , .. . . . . .. .. .. .. . . .. ...... .. .. ....... 119
Meters ........................................................................ 129
Engine Instruments and Alarms ........................................... 137
Low Ohm Meter ............................................................. 143
Battery Capacity Meter ..................................................... 145
Alternators ......................... ,......................................... 147
Manual Alternation Controls ................................................ 159
Charging Diodes ............................................................ 175
Table: How Much Current ................................. ,. .. . . .. .. .. .. . .. 179
Noise and Filters ............................................................ 181
Power for the Calculator ................................................... 185
American Boat & Yacht Council: Safety Standards ,.................... 191
Electric Power from the Sun ............................................... 193
Bilge Pump/Loran Supply Circuit ......................................... 196
Bilge Pump Alarm ........................................................... 197
Batteries and Battery Charging ............................................ 199
Lamp List ............................................................... ,.... 217
Printed Circuit Boards...................................................... 223
Wind Electricity ............ ,.. .... ........... ...... .. .... .. .................. 225
Index.......................................................................... 229
12 Volt Doctors Practical Handbook 1983 Beyn 0911551077
Download [13 KB]
The 12 volt doctor’s practical handbook for the boat’s electric system - Beyn E.J. [1983, PDF]
The 12V Doctors practical handbook - Edgar J. Beyn [1983, PDF]
Marine Electrical Check List (A Guide to Inspecting Marine Electrical Systems) - Robb Zuk [2014,…
Off Grid Solar Power - Tyler J. Green [2021, EPUB]
Boatowner’s Illustrated Electrical Handbook - Wing C. [2006, PDF]
Powerboater’s Guide to Electrical Systems - Edwin Sherman [2007, PDF]
Megger “A Stitch in Time...” (The Complete Guide to Electrical Insulation Testing) [2006, PDF]
Essential Boat Electrics - Carry Out Electrical Jobs On Board Properly & Safely - Manley P. [2021,…
The Boat Improvement Bible - Chamberlain-Webber J. [2015, EPUB]
Black & Decker The Complete Guide to Wiring, Updated 8th Edition: Current with 2020-2023 Electrical…
The time now is: Today 20:45
