zxc ®   02-Jan-2016 23:16
Marine Electrical Check List (A Guide to Inspecting Marine Electrical Systems)
Year: 2014
Author: Robb Zuk
Publisher: islandnet
Edition: 1
Pages count: 28
Description: This document is an explanatory guide for checking marine electrical systems. There are some great, detailed publications on this subject and I recommend them for additional reading when you have the time…
For now, this check list will get you started with a minimum of reading. I summarised points from Canadian, American and British marine wiring regulations. However, I did not quote these publications exhaustively so don't consider Marine Electrical Check List a legal document.
Before working on your system, clarify any confusing points with a professional electrician.
Introduction
• Stray Current
• Common Ground Point
• Batteries
• Connections
• Wires & Cables
• Labeling & Diagrams
• Battery Switch
• Fuses, Breakers & Switches
• Bilge Pump System
• Alternator
• Starter
• Anchor Winch / Windlass
• Battery Isolator (charging diodes)
• Battery Charger
• 120 Volt AC System
• Meters
• Bonding and Lightning Protection
• Corrosion Protection
• Compass
• Electrical Interference (noise)
• Miscellaneous
• Pre-Cruise Mini Check List
o Batteries
o Wiring & Connections
o Alternator, Starter & Winch Motor
o Miscellaneous
o Electrical System Spares
• References
Marine-Electrical-Check-List.pdf
Download [446 B]
The 12V Doctors practical handbook - Edgar J. Beyn [1983, PDF]
12 Volt Doctors Practical Handbook 1983 Beyn - Edgar J. Beyn [1983, PDF]
Boatowner’s Mechanical and Electrical Manual - How to Maintain, Repair, and Improve Your Boat’s…
The Marine Electrical and Electronics Bible - John C. Payne [2023, EPUB]
Understanding Boat Corrosion, Lightning Protection, and Interference - Payne J.C. [2005, PDF]
Off Grid Solar Power - Tyler J. Green [2021, EPUB]
Marine Electrical and Electronics Bible: A Practical Handbook for Cruising Sailors (Sheridan House…
Advanced Marine Electrics and Electronics Troubleshooting - Ed Shermann [2007, PDF]
3G Handy Guide: Electrician - 3G E-learning [2023, PDF]
Megger “A Stitch in Time...” (The Complete Guide to Electrical Insulation Testing) [2006, PDF]
The time now is: Today 15:25
