Arcan ®   16-Dec-2016 17:11
IMPA Marine Stores Guide v.1.1 4th Edition (Portable)
Year: 2004
Version: 1.1
Platform: PC (Windows)
Windows7 compatibility: yes
System Requirements: Win98/XP/7 x32 only, VGA, mouse, keyboard
Description: Portable version of IMPA Marine Stores Guide v.1.1 4th Edition.
Works without any CD.
Used onboard for ordering supply.
IMPA 4th Edition Version 1.1 (Portable)
Download [20 KB]
savdown   24-Dec-2016 17:21
Hi, thx for your effort but getting constantly the error ThinApp has encountered an unexpected error.Click Abort to close the application, Retry to debug, or Continue to ignore the error. Support info: PID=12056, Wow64.cpp@483 when i try to run it.
Arcan ®   24-Dec-2016 19:56
27506Hi, thx for your effort but getting constantly the error ThinApp has encountered an unexpected error.Click Abort to close the application, Retry to debug, or Continue to ignore the error. Support info: PID=12056, Wow64.cpp@483 when i try to run it.
Read carefully System requirements: works only with 32 bit systems. And will not work with x64. Do not try.
savdown   25-Dec-2016 10:47
27509
Thx for your answer, is there any chance it will be released for x64 systems too?
Arcan ®   25-Dec-2016 13:01
27513
27509
There are no idea to release it until will be released version of IMPA with support x64 systems.
If you would like to use it on x64 systems - the only one way i see - with using virtual engine (VirtuallBox or VMWare)
Jade30   26-Jul-2020 00:38
67395Jade30, ther are 6 seeders
0ReplyToggle Dropdown
thank you sir. im new here. im dowloading it for 3 days but always connecting to peer. but now its working
LSwir   26-Sep-2020 12:16
Одно мучение на современных ос, только через виртуалку, проще найти ISO образ IMPA Marine Stores Guide v.1.1 и закинуть на виртуальный диск, - работает без проблем, есть на всем известном трекере.
IMPA Marine Stores Guide v.1.1 4th Edition [2004]
User’s Guide CoCoS EDS (Engine Diagnostics System) Version 1.70 - MAN Diesel [2008, PDF]
ISSA Ship Stores Catalogue 2013 Edition (Portable) v.2.0 [2013]
M.O.T First Class Part (B) for Certificate of Chief Engineer ORAL Examination Questions and Answers ...
Crude oil tanker "British Kestrel" Bridge manual- Worldwide Marine Technology [2005, PDF]
Seagull Assistant v.7.10 - koldunoff [ADS] [2019] [Android]
ISGOTT - OCIMF [2006, PDF]
Seagull Assistant (Шпаргалка) v.7.2.1 - koldunoff [2020] [Android]
Ship AutomationFor Marine Engineers and ETOs - Witherby [2012, PDF]
Diploma in Ship Management - Module 1: Introduction to the Shipping Industry and the Role of the Shi...
The time now is: Today 08:45
