planet-yur ®   05-Jun-2013 19:02
Судовой палубный кран LIEBHERR CARGO DECK CRANE CBW 45(40)32/20(24,4)27,5 ST
Year: 2002
Author: LIEBHERR
Genre: Documentations
Publisher: LIEBHERR−WERK−NENZING GMBH
Number of pages: 102104
Description: This DOCUMENTATION has been prepared to allow the safe operation of the LIEBHERR crane while utilizing the crane’s full range of operating possibilities. In addition,
the manual emphasizes the daily routine maintenance and informs the operator of the operating principles of important assemblies and systems.
VOLUME 1 − INSTRUCTION / MAINTENANCE MANUAL
VOLUME 2 − TECHNICAL INFORMATION
Additional info: В раздаче содержатся 2 раздела
VOLUME 3 − SPARE PARTS LIST
The DOCUMENTATION is prepared for extended service−, repair− and maintenance
work as well as ordering spare parts. This manual shall be used by trained Service−per
sonnel only.
This LIEBHERR crane shall be operated and serviced by from LIEBHERR−WERK NEN
ZING trained or authorized personnel only.
The procedures described in the DOCUMENTATION and general safety precautions
shall be observed at all times.
NON−OBSERVANCE OF THESE RULES CAN RESULT
IN PERSONAL INJURY AND STRUCTURAL DAMAGE.
Special attention shall be given to the safety devices built−in to the crane. They shall
be tested at regular intervals for good condition and proper operation. Crane operation
is prohibited if the safety devices are not working properly.
"S A F E T Y A L W A Y S C O M E S F I R S T"
must be the way of thinking and behaviour before, during and after crane operation.
If you receive any further information for the crane, such as technical modifications or
changes concerning operation, maintenance, or spare parts − please attach them to
provided volumes.
INDEX − VOLUME 1
1. PREFACE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5
1.1. TO THE OWNER . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5
1.2. GENERAL INFORMATION . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.6
1.3. CRANE APPLICATION AND OPERATION . . . . . . . . . . . . . . . . . . . . . . . . . 1.6
1.4. CONVERSION TABLE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.8
1.5. STANDARD HAND SIGNALS FOR CONTROLLING CRANE
OPERATIONS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.9
1.6. GENERAL HINTS AND ADVISE FOR CRANE OPERATION . . . . . . . . . . 1.10
1.7. EXPLANATION OF SAFETY SIGNS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.15
1.8. LIEBHERR WORLD−WIDE SERVICE ORGANIZATION . . . . . . . . . . . . . . 1.19
2. GENERAL DESCRIPTION . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.3
2.1. ARRANGEMENT OF THE MAIN PARTS OF THE CRANE . . . . . . . . . . . . 2.3
2.2. TECHNICAL DESCRIPTION OF THE CRANE . . . . . . . . . . . . . . . . . . . . . . 2.8
2.3. LAYOUT OF THE OPERATOR’S CABIN . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.12
2.4. CONTROLS ON THE SWITCH CABINET X1 . . . . . . . . . . . . . . . . . . . . . . . 2.17
2.5. PREPARATIONS FOR CRANE OPERATION . . . . . . . . . . . . . . . . . . . . . . . 2.19
2.6. CRANE OPERATION . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.20
3. MAINTENANCE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.3
3.1. GENERAL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.3
3.2. SPECIAL SAFETY REGULATIONS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.4
3.3. MAINTENANCE OF HYDRAULIC SYSTEM . . . . . . . . . . . . . . . . . . . . . . . . 3.9
3.4. PRESSURE ACCUMULATORS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.13
3.5. LIEBHERR CONDITION MONITORING . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.14
3.6. GEARBOXES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.19
3.7. MULTIPLE DISC BRAKES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.22
3.8. INSTRUCTIONS FOR USE OF CRANE ROPES . . . . . . . . . . . . . . . . . . . . 3.23
3.9. REPLACEMENT OF ROPES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.27
3.10. ROPE PULLEYS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.29
3.11. ROLLER SLEWING RING . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.32
3.12. ELECTRICAL SYSTEM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.33
3.13. MAINTENANCE INSTRUCTIONS FOR SLIP RING UNIT . . . . . . . . . . . . . 3.34
3.14. LUBRICATION AND GREASING DIAGRAM . . . . . . . . . . . . . . . . . . . . . . . . 3.35
3.15. MAINTENANCE LISTS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.37
3.16. SERVICE SPARE−PARTS AND STANDARD TOOLS . . . . . . . . . . . . . . . . 3.53
Cargo Deck Crane-LIEBHERR
Download [9 KB]
Liebherr Cargo deck crane CBW 40 / 29,5 ST (Instruction manual + Technical information) [2000, PDF]
Liebherr Crane CBG 30/28 Litronic (Technical information + Operating manual + Video) [2006, PDF]
NMF Crane DK II 45 t. 45027,5/35032,2 (Instruction manual) [2005, PDF]
Alfa Laval S966 Separator Instruction Manual - Alfa Laval Tumba AB [2017, PDF]
NMF Crane DK II 250012/100026 (Operating Manual + Assembly instruction) [2002, PDF]
Alfa Laval MAB 103B-24 Separator Instruction Manual - Alfa Laval Tumba AB [2019, PDF]
NMF Board crane DK III 45026,8/40029,5 (Instruction Manual + Addons) [2002, PDF]
Guidance Manual for Weatherdeck Hatch Covers - TTS Ships Equipment GmbH [2006, PDF]
7S70ME-C Electronic Manual (Operation, Maintainance, Description, Accessories) - MAN B&W Diesel…
Alfa Laval P615 Separator (Instruction manual | Spare parts catalogue) - Alfa Laval [2009, PDF]
The time now is: Today 16:46
