bubba ®   20-Aug-2016 17:37
LNG Cargo Simulator
Developer: Kongsberg
Year:: 2007
Version:: 1.00
Description: 1. After starting up the simulator and choosing a scenario, it is advisable not to chose another scenario. If you wish to run a new scenario it is best to terminate the simulator and re-start.
2. Operations that take a long time to finish, such as bulk (de) ballasting, bulk loading etc, can be speeded up using the ‘simulate 10x fast’ button. This will speed up time to a factor 10 (or 100 if you click the button again) in all running processes. The following screens contain this button:
-. Cargo main screen
- Loading screen
- Unloading screen
2. Ballast screen
The setting of the gas return valve CG001 is in this case erratic and needs to be adjusted continuously. The barrier pressures will be frozen in time during speeded up scenarios.
3. Some of the operations as described in the tutorials deviate slightly from the deck info book (such as the use of manifold bypass valves for cool down). This was necessary for software technical reasons.
LNG Cargo Simulator.rar
greenmicro   16-Jan-2019 04:08
bubba, Thanks a lot for this great simulator. But i just try it and found several bugs which make it crash. Would you share another similar program like this? This is very helpful. Thank you
blakd33p   14-Feb-2026 05:55
TS may i ask if you can seed this software, i need this software for calculation, Thanks you
Kongsberg SP Dual Fuel Simulator v.2.4.0.0259 Instructions Manual- Kongsberg [2009]
Coastal Cruising Simulator r.8 [2002]
ClearWater Cargo Assistant/II (R) Ship Loading Program In-house training [2009]
LNG Cargo Operations (SIGTTO Management Level) 4 Days Course Material - GTT Training [2019, PDF]
LNG Cargo Operations SIGTTO Management Level - GTT Training [2021, PDF]
Bulk Carriers - Guide & Info on Bulk Cargo Loading to Reduce the Likelihood of Over-stress the Hull ...
Bulk Carriers | Guidance and Information on Dry Cargo Loading and Discharging to Reduce the Likeliho...
Guidance and Information on Bulk Cargo Loading and Discharging to Reduce the Likelihood of Over-stre...
Bulk Carriers Handle With Care - IACS [2012, PDF]
How to prevent tanker shortage claims - Thomas Miller [2011, PDF]
The time now is: Today 22:23
