EnigmaII   18-Jan-2026 18:45
Hello
Does anyone have a working code for SDVJANM300MAP12.dbv for TZ ProV4 .. I have tried UC 2B6EA9F7AD6CABDF12FE With no Luck...
Cheers
Cerrias   18-Jan-2026 20:43
112015Hello
Cheers
zeimer   24-Jan-2026 20:15
THOMZY,
See my previous comment:
If you are having TLS issues with Map Manager not downloading and installing the charts automatically with "Error, the request was aborded: could not create SSL/TLS secure channel".
I fixed it by forcing Windows to use TLS 1.2 even for old software by adding two registry keys:
1. Press Windows + R, type regedit, and hit Enter.
2. Go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\v4.0.30319
3. Right-click the right pane → New → DWORD (32-bit) → name it: SchUseStrongCrypto
4. Set its value to: 1
5. If you’re on 64-bit Windows, repeat the same under: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\.NETFramework\v4.0.30319
6. Restart Windows and try Map Manager again.
If this doesn't work, you can still manually download the charts with your browser and add the UC in TimeZero manually.
8
44U   25-Jan-2026 14:00
Hallo..
Why does Timzero Nav4 4.2.0.133 always exit by itself when opened?
can anyone help me plis..?
Salimaster   05-Feb-2026 16:01
Hello everyone! Can someone help me with the high-definition Mediterranean maps?
High Resolution Bathymetry
Eastern Mediterranean.
Tnx
enbodi   06-Feb-2026 15:22
Good afternoon, could you please provide me with a forum for the Furuno NAVNET XL fishfinder/plotter? Thank you very much.
mustaphabenisaf   Yesterday 06:28
phoenix84,
SDVJEMM112MAP31.dbv UC Code B8BDA6E62F83AEE431DD
SDVJEMM017MAP31.dbv UC Code 5867E17645ECC2393127
SDVJEWM010MAP31.dbv UC Code 4DF371146ADCB82E313A
The time now is: Today 00:51
