twicer ®   11-May-2022 11:49
Nautical Calculator Pro
Year: 2022
Version: 9.2.0
Developer: Giacomo Gabriele
Platform: Android
System Requirements: Requires Android 5.0 and up
Crack: Not needed (“about” not showing as a pro but all functions of pro version are working, presumed)
Description: Nautical Calculator is an excellent tools, which covers every aspect of nautical and astronomical navigation and solves every concerning spherical-trigonometrical problem.
The app work totally off-line, can use gps position for calculation and can export calculation data with charts in pdf file. The automatism of Nautical Calculator have been implemented and tested since long time through many thousands users' cooperation and acknowledgement all over the world.
It confirms students teachers and navigators awareness and satisfaction on using the program.
In routes feature there is a world map: it isn't a nautical chart and is not for use as a saling chart, but as a simple general means of showing the courses through the water on earth, this map isn't for navigational purposes. No need connection for show the map; the map will be downloaded only one time. The map, for size limit, will be show for scale over 60-70 Nm.
Release date : April 26, 2022
Main Features
Nautical Calculator Pro is the most complete application that solves the navigation calculations
The main features are :
- Calculate Route (solves 2nd navigation problem)
- Calculate point on Rhumb Line (solves 1st navigation problem)
- Calculate point on Great Circle (solves 1st navigation problem)
- Calculate point on WGS84 (solves 1st navigation problem)
- Calculate Average speed
- E.T.A. calculation
- Route plan, for manual waypoints planning
- Waypoint route
- Compisite sailing with parallel limit
- Rhumb Line Parallel/Meridian intersection
- Follow on same Rhumb Line route
- Opposite course rendez vous
- Route correction
- Calculate Amplitude at sunset and sunrise and magnetic compass deviation
- Compass detections
- Solves Drift problem
- Solves Tides problem
- Solves Tidal current problem
- Wind calculation with Beaufort classification
- ABC Tables (azimuth, initial course, right ascension with unknow star)
- Nautical almanac
- Celestial Navigation with position line
- Meridian transit
- Celestial observation
- Coastal navigation
- Wheel Over
- Draft survey
- Converter
- Anchorage
- Interpolation
- NEW v9.2 Add new feature: Moon phases
Nautical Calculator Pro_ver 9.2.0 2022.apk
Download [4 KB]
twicer ®   07-Jul-2022 14:37
Markuz, yes, “about” not showing as a pro but all functions of pro version are working, presumed
Celestial Navigator v.3.2 [2017] [Android]
Navigator HD v.3.7.1 - Omar Reis [2022] [Android]
VRTool v.3.9.1 - Omar Reis [2022] [Android]
AstroNav v.1.1.7 - Navsoft [20??]
Navigation calculator v.0.0.40 - DBG Nautical [2019] [Android]
CamSextant v.3.0.1 - Omar Reis [2022] [Android]
Compact Data for Navigation and Astronomy, 1996-2000 - B. D. Yallop & C. Y. Hohenkerk [1995, PDF]
Compass Calculator v.0.0.90 - DBG Nautical [2019] [Android]
TELchart v.3.5.32 [2011]
The Cutterman’s Guide to Navigation Problems - Christopher D. Nolan [2016, PDF]
The time now is: Today 18:44
