123dfhw32   01-Oct-2025 08:37
Друзья всем доброго времени суток доброго здоровья, у кого есть UC для SDVJRSM202MAP27.dbv пришлите пожалуйста!... если есть свежий файл Charts UC code поделитесь пожалуйста. Заранее благодарю. Всем мира!
zeimer   11-Oct-2025 16:56
If you are having TLS issues with Map Manager not downloading and installing the charts automatically with "Error, the request was aborded: could not create SSL/TLS secure channel".
I fixed it by forcing Windows to use TLS 1.2 even for old software by adding two registry keys:
1. Press Windows + R, type regedit, and hit Enter.
2. Go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\v4.0.30319
3. Right-click the right pane → New → DWORD (32-bit) → name it: SchUseStrongCrypto
4. Set its value to: 1
5. If you’re on 64-bit Windows, repeat the same under: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\.NETFramework\v4.0.30319
6. Restart Windows and try Map Manager again.
If this doesn't work, you can still manually download the charts with your browser and add the UC in TimeZero manually.
nugrohot   13-Oct-2025 10:30
After entering AC and clicking on the "ACTIVATE" button, the program crashes, close TZ. Is there any solution to this problem ?
The time now is: Today 18:59
