twicer ®   24-May-2025 11:48
Guidelines on Main Propulsion Shafting Alignment
Year: 2025
Author: IACS
Publisher: International Association of Classification Societies
Edition: Rec.185 February 2025
Pages count: 11
Description: The objective of this new Recommendation is to provide guidance for the propulsion shafting alignment design, installation and verification in order to achieve a satisfactory shaft alignment condition. The aim is that the proposed set of recommendations will lead to the definition of minimum criteria, which could be standardized across the various shipyards’ practices.
This Recommendation provides a unified approach in the alignment design, analysis and application of propulsion systems with oil lubricated bearings, including Environmentally Acceptable Lubricants.
The new IACS Guidelines are anticipated to greatly improve the reliability of propulsion systems globally, thereby enhancing vessel safety.
na
Guidelines on Main Propulsion Shafting Alignment (Rec.185).pdf
Download [443 B]
Classification societies – what, why and how?, Updated 2015 - IACS [2011, PDF]
Guidance Notes On Ship Vibration - ABS [2006, PDF]
Requirements for Methanol and Ethanol Fueled Vessels - American Bureau of Shipping (ABS) [2025, PDF]
Recommendation for conducting commissioning testing of Ballast Water Management Systems -…
Guidance Notes on Propulsion Shafting Alignment - ABS [2019, PDF]
Requirements for Hydrogen Fueled Vessels - ABS [2023, PDF]
Design and Operations of Double Hull Tankers - RINA [2004, PDF]
Guidance Manual for Tanker Structures, 2024 Consolidated Edition - Witherby / Tanker Structure…
Cyber Resilience Guidance - ABS [2026, PDF]
Guidelines for Designing Cyber Security Onboard Ships - ClassNK [2020, PDF]
The time now is: Today 16:29
