Sate   16-May-2024 22:01
101036Hi all, good day.
Need code for chart:
SDVJEMM076MAP27
Thanks in advance ????
76CC5DE992E4AC9B276D
k33t   19-May-2024 19:21
Hello guys, I was wondering if anybody had a key for SDVJENM405MAP27.dbv ?
I was also thinking , when i clicked on the map area I wanted on the Time Zero website, it gives me first the vector option, which is the chart im looking for a key.. But then there is also "3D" maps there called SDEN01TIN01.dbt and SDNA01TIN01.dbt , are these something I could use and do I need other keys for these maps ? Im using Time Zero 4.2, that should support 3D maps ?
Sate   21-May-2024 00:46
101115Hello guys, I was wondering if anybody had a key for SDVJENM405MAP27.dbv ?
8D1317202EE9257F27D8
Honestly, i dont know how works 3d charts, i have not code for it and some charts say "Unlocked" but i see the same ( in 3d) that if im using vector charts.
k33t   22-May-2024 00:11
Sate, Thank you very much for the key , it's ok i dont really need those 3d maps, i was just curious about them, the vector map is what i will mostly be using anyway :)
Andragom   24-May-2024 08:20
Olá amigos, baixei o TZ Professional, fiz o passo a passo da ativação até iniciar o programa, ele está pedindo ativação / login na conta mytimezero.com, as funções de tempo, clorofila da água e vento não funciona alguém poderia me ajudar?
matrixdu   24-May-2024 08:23
Andragom, Installation instructions: 1.Turn off internet connection 5. run block host and finally turn off internet connection in mxtz options
BobbyDigital   24-May-2024 21:30
Подскажите кто то подключал ARPA через Lan радар фуруно, у меня только оверлей картинка но нет арпы
Musel   26-May-2024 18:26
BobbyDigital,
I don't know what model of Radar you have.
But for the TTM to pass through LAN you have to configure the output.
2XX7 Configuration:
The ARPA target output must be setup through the LAN from one FAR2xx7. Hold “HL OFF” and press the “MENU” key 5 times. The “Initialize” menu appears. First, select “TT Preset” (6). Select “True” for “TTM Output” (2). Select “Back” to return to the “Initialize” menu and select “Other” (8). Set “INS” (5) to “LAN”.
TimeZero Configuration:
In order for the ARPA target to be received over the network, you need to configure it manually in the software:
Open the Connection Wizard
Select "Manual Port Configuration" and click on "Next"
Select "Add/Configure UDP Connection" and click on "Next"
Select the IP address that begins with 172.31.x.x from the "Network Adapter" drop down menu and type "10028" for the "UDP Port". Click on "Next"
When TimeZero is done analyzing the port, select “UDP 10028” in the list on the left and make sure that “ARPA” is checked in the list on the right. Click "Next" then "Finish".
Arpa LAN
The time now is: Today 09:13
