a_koseoglu   30-Apr-2024 10:30
87828Dear All ,
After all procedure i am starting programbut can not see SC code.. What is the problem.. All looks OK but Time Zero giving me error.. No SC Code ???
Problem.resolved
Hectoriano   05-May-2024 07:07
hola eso se debe a que estas conectado a internet y maxsea te envia los codigos a los fabricantes y te bloquean, debes desconectar internet en el maxsea en opciones
matrixdu   05-May-2024 07:38
didi01, find and delete
C:\Users\yourusername\Documents\Temp\{aaa3e21c64-63sdf25-1654e-zg1-0856410318}
C:\Users\yourusername\AppData\Roaming\Temp\{6f3e96c64-64f325-12ce-bhc1-08102bf10318}
C:\ProgramData\CrypKey\{4d36e96c-e325-11ce-bfc1-08002be10319}
C:\Users\yourusername\AppData\Local\Temp\{5e3e96c-e325-11ce-bfc1-08002be10319}"
C:\ProgramData\Temp\{8f3e21c64-63f325-12ce-z5g1-081999f10318}
TZ option-> Initial Setup
Set Connect to internet option to Never
The time now is: Today 11:50
