SailorF54   15-Feb-2022 10:27
FLPF2012,
GPS: Click on the folder icon at top right end of screen. Select 'setup' tab in the right-hand column display, then 'nmea data ports' in the drop-down menu. Active data port is shown by a white tick mark (not greyed out') on the left column of the pop-up window.. Tick (click) the relevant one, Test it by selecting this data port, and speed (usually 4800). Data should be streaming in the lower part of the window. Click OK to close the window. The numerical position will appear in the top part of the column display, and there will be an icon on the chart.
Guest   20-Nov-2022 10:49
23873Installed program and registered/licensed charts but I'm getting a message
C-Map
g_manager->init() failed
What am I missing
Thanks in advance
Lin Myint   05-Feb-2023 21:26
installed the program but where can i downlod the chart??
Under the following C-MAP is missing.
Can you help me, Pls.
help..JEPPESEN C-MAP Professional+ / CM93 v3 / WF745https://mega.nz/#!PFQESDqK!fCU-...sKfAQIrsL9HxkswY
Paulyong   12-Mar-2023 15:16
dkoslow, M@riner,
in Cm-93/3 Database Administrator
- unregister database first.
- restart Pc, reinstall the program.
startermot   28-Mar-2023 20:56
Hello, i´ve a Telchart v1.4 with lot of tracks, marks and routes. I need to convert it to new software Telchart V3 or similar
I tried to export to floppy disk (it´s the only option available) but it outputs a Telchart.dat and new Telchart can´t read it.
How can i export it? can anyone help me, please?
startermot   30-Mar-2023 10:31
Hello, i´ve a Telchart v1.4 with lot of marks and tracks. I need to convert it to Telchart v3. How can i do it? Telchart v1.4 only can export to Floppy disk.
Thanks
cvaigon   27-Apr-2024 20:03
ПОДСКАЖИТЕ ЗА КОРРЕКТУРУ .
СТАРУЮ MAX SEA.
В КОТОРОЙ ОТОБРАЖАЮТСЯ СИБИРСКИЕ РЕКИ В 3D ВИЗУАЛИЗАЦИИ
Все какие есть- Обь, Иртыш , Тобол, и далее по списку вплоть до Лены, а лучше до Амура (ведь когда-то канал Москвы- реки отображался).
Для оболочки TEl Chart .
Пусть даже 5-7 летней давности.
Очень нужно .
The time now is: Today 16:38
