twicer ®   07-Jun-2026 10:45
Reeds Marine Distance Tables
Year: 2026
Author: Kendall Carter
Genre: Reference Books
Publisher: Bloomsbury Publishing
Edition: 19th
ISBN: 9781399421164
Pages count: 241
Description: These tables provide distances between over 500 ports worldwide. By consulting them the user can calculate the shortest distance between all the major ports around the world. The ‘market areas’ are presented with the ship owner or broker in mind to allow quick and easy estimating, but they are also a handy reference for any master or navigator.
The pull-out world map shows these trading areas and directs the user to the appropriate section of the book. Every port with an entry in that section is shown on the individual chartlet at the front of it. The key market areas (A–H) are also linked to each other in order to give distances to ports in other market areas.
Whilst these tables were originally intended for commercial trading purposes, their use has expanded to include superyachts and cruise vessels. For this reason some of the regularly visited leisure ports have been included.
This edition has included seven new ports, Bodø, Hammerfest Holmsund and Oulu in Area A, Punta Arenas in Area D and Machilipatnam and Neom in Area E. A total of 508 new distances have been included to accommodate these new ports, significantly improving the utility of the tables but without significantly increasing its size.
Reeds Marine Distance Tables 19Ed 2026.pdf
REEDS Marine Distance Tables - Miranda Delmar-Morgan, Kendall Carter [2024, PDF]
Reeds Marine Distance Tables - Miranda Delmar-Morgan [2022, PDF]
Reeds Marine Distance Tables - Compiled by: R.W. Caney & J.E. Reynolds, Revised by: Miranda Delmar-M...
Japanese Distance Tables [1990, PDF]
REEDS PBO Small Craft Almanac 2024 - Perrin Towler, Mark Fishwick [2023, PDF]
REEDS PBO Small Craft Almanac 2023 - Perrin Towle, Mark Fishwick [2023, PDF]
REEDS Ocean Handbook - Bill Johnson [2015, PDF/EPUB]
Lloyd’s Maritime Atlas, Edition 30 - Informa UK Ltd [2018, PDF]
Ship Master’s Manual Automated On Board Weather Routing System - RealDistance.com [2007, PDF]
Maintenance and Repair for Diesel Engines - Jean Luc Pallas [2013, PDF]
The time now is: Today 19:24
