Year: 2025 Version: 4.6.0 Developer: Royal Netherlands Meteorological Institute (KNMI) Platform: Windows & Linux 64-bit OS compatibility: yes System Requirements: MS Windows (32 bit & 64 bit) / Linux Localization: English Crack: Not needed Description: TurboWin was developed at KNMI (Royal Netherlands Meteorological Institute) with contributions from several National Meteorological Services and endorsed by the WMO (World Meteorological Organization) and E-SURFMAR (European Surface Marine Program). Meteorological observations made on board ships and fixed sea stations are a substantial component of the World Weather Watch, providing observations that are accurate and of high quality. The fixed sea stations and VOS (Voluntary Observing Ship) program are key components of the GOOS (Global Ocean Observing System) and climate research. To achieve an optimal control of the quality of the observations, before they are used in real time forecast, the quality control has to be carried out at the observing entry points, by the observers themselves. TurboWin contains observation checking routines which are applied on the observations before they are transmitted. TurboWin is a user-friendly system with over 200 built-in quality checks. The software is used for logging and encoding observation and assists with transmission on board ships and fixed sea stations. The Turbowin software assists the observer with many menus, pictures, photos, forms, help pages, output options, automated calculations etc. Additional info: There are several options available for either Windows or Linux machines. Some versions also require Java to be installed. Previous versions of TurboWin should be Uninstalled prior to continuing with the installation of a newer version. Latest version can be accessed fromhttps://gitlab.com/KNMI-OSS/turbowin/turbowin
How to install
- [TurboWin+ V4.6 Windows 64 bit (55 Mb; no Java required)]("\TurboWin\binaries\TurboWin+_V4.6.0-64bit.exe")* - [TurboWin+ V4.6 Windows 32 bit (37 Mb; Java JRE 8+ required)]("\TurboWin\binaries\TurboWin+_V4.6.0-32bit.exe") - [TurboWin+ V4.6 Linux 64 bit [rpm] (59 Mb; no Java required)]("\TurboWin\binaries\TurboWin+_4.6.0-1.x86_64.rpm") - [TurboWin+ V4.6 Linux 64 bit [deb] (59 Mb; no Java required)]("\TurboWin\binaries\TurboWin+_4.6.0-1.deb")
TurboWin+
Version: 4.6.0
Crack: Not needed
Latest version can be accessed from https://gitlab.com/KNMI-OSS/turbowin/turbowin
How to install
- [TurboWin+ V4.6 Windows 64 bit (55 Mb; no Java required)]("\TurboWin\binaries\TurboWin+_V4.6.0-64bit.exe")*- [TurboWin+ V4.6 Windows 32 bit (37 Mb; Java JRE 8+ required)]("\TurboWin\binaries\TurboWin+_V4.6.0-32bit.exe")
Notice from: zxc
Reference Book:
https://seatracker.me/viewtopic.php?t=4598
TurboWin
Download [77 KB]
Share
