seanavigator847 ®   28-May-2026 22:50
IICL: General Guide for Container Cleaning, 3rd Edition
Year: 2019
Author: IICL
Edition: 3rd
Pages count: 110
Description: This Guide uses color photographs to illustrate different types of container conditions in dry van, open top and refrigerated containers that may or may not require cleaning. For each condition, the Guide recommends the action to be taken, if any, and the cleaning procedure to use, if the container requires cleaning. Areas covered include general principles for determining when to clean, possible harmful contamination and recommended action, and recommended cleaning methods for all types of conditions.
IICL General Guide for Container Cleaning-3rd.pdf
Download [14 KB]
IICL: Guide for Flatrack Container Inspection - IICL [2003, PDF]
IICL: Supplement on Inspection & Repair - Gray Areas, 2nd Edition - IICL [2003, PDF]
IICL: Repair Manual for Steel Freight Containers, 5th Edition - IICL [2006, PDF]
Guide for Container Equipment Inspection 5th Edition [2006, PDF]
IICL: Guide for Container Equipment Inspection, 6th Edition - IICL: Guide for Container Equipment In...
IICL: General Guide for Refrigerate Container Inspection and Repair, 4th Edition - IICL [2016, PDF]
Prevention of pest contamination of containers: Joint Industry Guidelines for Cleaning of Containers...
D J House - Cargo Work For Maritime Operations - D. J. House [2005, PDF]
Polar Ship Certificate Guidance | Polar Code Guidance - Maritime New Zealand [2018, PDF]
NOAA - Shoreline Assessment Job Aid - NOAA [2007, PDF]
The time now is: Today 14:26
