lexusjc ®   16-May-2026 10:50
Shipyard paper models 21 ship with aftermarket 3d stl elements for printing and laser cut templates
Year: 2026
Language: English / Русский
Author: Lexus JC
Genre: Model Making
Description: This project was created to solve the following problems inherent in the original and scanned versions that you can freely download on the internet:
  • Many of the magazines are no longer being published
  • It has low print quality
  • It doesn't satisfy those who want the model to look like it's made of wood, as the original lacks wood texture
  • The appearance of decorative elements is unsatisfactory
  • There are no supplements in the form of laser-cut and 3D-printed elements
  • It's sometimes difficult to find the required element in the instructions
Описание: Этот проект появился для того, чтобы решить следующие проблемы, присущие оригиналу и сканированным версиям, которые вы можете свободно скачать в интернете:
  • Многие из журналов уже не издаются
  • Имеют низкое качество печати
  • Не подходят тем, кто хочет, чтобы модель выглядела как сделанная из дерева, так как у оригинала отсутствует текстура дерева
  • Не устраивает вид декоративных элементов
  • Отсутствуют дополнения в виде лазерной резки и 3D-печатных элементов
  • Иногда сложно найти в инструкции нужный элемент
More info
What distinguishes this magazine from other versions:
  • 600 dpi resolution providing maximum print quality without artifacts
  • All magazines are formatted so that the sheets are A4 size, while maintaining the model's scale. This advantageously distinguishes this edition from the original, where most models are presented on A3 sheets, and makes home printing accessible
  • Sheets with parts have centimeter rulers horizontally and vertically, which makes it possible to fully maintain geometry when printing
  • Wooden parts have appropriate texture, unlike the original, which gives the model the quality of a wooden kit
  • This edition has interactive navigation and a table of contents. In any diagram or on any parts sheet, you can click on a number and go to the interactive table of contents, which has 3 columns: 1 - part number; 2 - all links on diagrams; 3- all links on parts sheets. Moreover, each link has two numbers in parentheses that correspond to X and Y coordinates in centimeters, counted from the upper left corner. This allows you to quickly find parts even by simply printing the interactive table of contents
  • Contains links to Thingiverse where you can freely download files for laser cutting of the ship's hull and decks, as well as 3D models of decorative elements, artillery, and rigging elements
Что отличает этот журнал от остальных версий:
  • Разрешение 600 dpi, обеспечивающее максимально качественную печать без артефактов
  • Все журналы свёрстаны таким образом, что листы представляют собой формат А4, при этом масштаб модели сохранён. Это выгодно отличает данное издание от оригинала, где большинство моделей представлены на листах формата А3, и делает доступной домашнюю печать
  • Листы с деталями имеют сантиметровую линейку по горизонтали и вертикали, что даёт возможность полностью соблюсти геометрию при печати
  • Деревянные детали имеют соответствующую текстуру, в отличие от оригинала, что придаёт модели качество wooden kit
  • Данное издание имеет интерактивную навигацию и оглавление. В любой схеме или на любом листе с деталями можно кликнуть по номеру и перейти к интерактивному оглавлению, где имеются 3 колонки: 1 - номер детали; 2 - все ссылки на схемах; 3 - все ссылки на листах с деталями. Причём каждая ссылка имеет в скобках две цифры, которые соответствуют координатам X и Y в сантиметрах, считая от верхнего левого угла. Это позволяет быстро отыскивать детали, даже просто распечатав интерактивное оглавление
  • Содержит ссылки на Thingiverse, где вы можете бесплатно скачать файлы для изготовления лазерной резки каркаса корабля и палуб, а также 3D-модели декоративных элементов, артиллерии и элементов такелажа
  • Berbice
  • HMB Endeavour
  • HMS Alert
  • HMS Bellona
  • HMS Cleopatra
  • HMS Enterprize
  • HMS Granado
  • HMS Revenge
  • HMS Victory
  • HMS Wolf
  • La Belle Poule
  • Le Coureur
  • lUSS Lexington
  • Nina
  • Papegojan
  • Pinta
  • Santa Leocadia
  • Santa Maria
  • Schwarzer Rabe
  • Xebec
  • Yacht Chatham
  • Screenshots
    shipyard-models  GOLDEN RELEASE!
    Download [304 KB]
    HMS Granado 1742 года модифицированный (модель из бумаги) - LexusJC [2016, PDF]
    Shipyard - подборка любительских журналов, посвященных сборке бумажных парусников. [JPG]
    Корабль адмирала Нельсона Виктори (120 выпусков) - DeAgostini [2012, PDF, JPEG]
    Victotia-class Battleship HMS Victoria (1887) - Paper Model - CarlP. Beetz [2009, JPEG]
    Такелаж моделей исторических кораблей - Леннарт Петерссон [2000, PDF]
    Modelling The New York Pilot Boat Phantom 1868 (MS2027) - Passaro C. [2009, PDF]
    Beginner’s Guide to Building Ships in Bottles - William Sheridan [2020, PDF]
    Конвертирование книг формата eBook (ebk) в PDF / EBK to PDF converter
    Модель Туры князя Святослава - ЮМКТ - Е.Половинник [2014, JPEG]
    Ищу издания английского адмиралтейства NP для создания полной раздачи
    The time now is: Today 15:47
