seanavigator847 ®   14-May-2026 13:33
The use of moisture meters on small craft
Year: 2020
Author: Jeffrey Casciani-Wood
Genre: Shipbuilding
Publisher: IIMS
Pages count: 36
Description: The first thing to know about moisture meters is that they do not actually measure moisture. What they do measure is conductivity. The origins of the moisture meter lie in the building and construction industries and the original scale was based on the water content of brick and stonework. The scale has largely remained unchanged. There are a number of these machines available in the market and they were first introduced into the marine industry for checking how an frp hull had dried over time prior to rebuilding for osmosis treatment and for that they remain a useful tool. They are also used to check for moisture below a surface that looks dry.
Electrical moisture meters have an enormous advantage for the general survey as they are clean and nondestructive, but they do have limitations and they do NOT quantitatively measure moisture on/in hull substrates. The majority record electrical resistance between two applied electrodes or capacitance and, more recently, some measure the reflection of radio frequency emissions from the meter.
The-use-of-moisture-meters-on-small-craft.pdf
Download [4 KB]
Biological attack on iron and steel - Jeffrey Casciani-Wood [2020, PDF]
Small steel craft: design, construction and maintenance - Ian Nicolson [1983, PDF]
Rebuilding the Royal Navy - Warship Design Since 1945 - Brown D.K. [2012, EPUB]
Energy Efficiency Clauses in Charter Party Agreements - George Adamantios Psarros [2017, PDF]
Glossary of ship and boat-building terms - F. Forrest Pease [?, PDF]
WIG Craft and Ekranoplan - Ground Effect Craft Technology - Yun L., Bliault A., Doo J. [2010, PDF]
Guide for Alternative Requirements for Hull Construction of Vessels Intended to Carry Vehicles (130…
Ship Construction and Welding - Mandal, Nisith Ranjan [2017, PDF]
Exploration of Gas Hydrates - Geophysical Techniques - Naresh Kumar Thakur & Sanjeev Rajput [2011,…
User Manual & Product Guide - WEST SYSTEM Epoxy [2020, PDF]
The time now is: Today 14:34
