Технарь ®   17-Apr-2025 20:36
MAN B&W S46ME-B8.5-TII – Project Guide
Year: 2016
Author: MAN
Genre: Instruction Manual, Project guide
Publisher: MAN
Pages count: 355
Description: This Project Guide provides preliminary technical information for planning and designing a marine propulsion system based on the MAN B&W S46ME-B8.5-TII electronically controlled two-stroke engine with camshaft-controlled exhaust valves.
The guide is intended for use during the project planning stage and includes general layout recommendations, technical specifications, and performance data. All information is subject to change and should not be used for detailed design or construction purposes.
Key features:
  • Engine type: Electronically controlled two-stroke with camshaft-controlled exhaust valves
  • Purpose: Marine propulsion layout planning
  • Status: Preliminary data, subject to updates
  • Availability: Electronic version and updated sections available online at www.marine.man.eu → Two-Stroke
Important Notes:
  • Some values and figures are indicative and may be marked as “Available on request” or “Not applicable.”
  • Final engine design and detailed documentation are provided by the licensed engine manufacturer, as outlined in Chapter 20.
"Extent of Delivery" forms detail standard and optional equipment, facilitating communication between shipyards, engine makers, and customers.
MAN B&W S46ME-B8.5-TII Project Guide.pdf
MAN B&W S70ME-C8.5-TII Project Guide Electronically Controlled Two-stroke Engines - MAN [2018, PDF]
MAN B&W Two-stroke Marine Engines Emission Project Guide for Marpol Annex VI Regulations - MAN…
MAN B&W S35MC-C9.2-TII Project Guide - MAN Diesel & Turbo [2014, PDF]
MAN B&W Low Speed Small Bore Engines Now with Electronic Control - MAN [2014, PDF]
INSTRUCTION MANUAL FOR THE USE OF IHO TEST DATA SETS IN ECDIS _Publication S-64_ IHO TEST DATA SETS…
Modern Marine Internal Combustion Engines: A Technical and Historical Overview - Levgen Bilousov ,…
CD-01-4 MAN B&W 50MC-C/ME (Maritime Electronic LIbrary) - ERMO83 [2007, PDF]
Recommendations For Relief Valves On Gas Carriers - SIGTTO [2020, PDF]
Marine Medium Speed Diesel Engines - S. H. Henshall [1973, PDF]
The time now is: Today 15:07
