5sb1 ®   17-Feb-2025 14:10
Ceramic Burners for Model Steam Boilers
Year: 2020
Author: Alex Weiss, Kevin Walton
Pages count: 302
Description: This book covers the materials needed to make ceramic burners and explains how to silver solder them. It discusses LPG and holding tanks, as well as connecting pipework and electronic and mechanical automatic gas-control systems to monitor the boiler pressure. In addition, there is advice on how to set up, install and operate each burner to provide optimum heating to the boiler. A summary of the Boiler Test Code Volume 3 that applies to home-made gas tanks is included, together with a list of useful suppliers with their contact details. This book provides all the information you need to build and operate: three burners, with one variant, for boilers with 42mm, 35mm and 28mm horizontal flues; two round burners for vertical boilers with fire boxes; two different sizes of rectangular burner, with one variant, for use in horizontal water-tube or pot boilers and finally, one small round and one tiny oblong burner for use in Mamod and Wilesco boilers. The burners described are straightforward to make and simple to use to heat the water in boilers that meet the 3 bar litre limit in the UK Boiler Test Code.
Ceramic Burners for Model Steam Boilers - Alex Weiss.pdf
Download [18 KB]
Making Small Gas-Fired Boilers for Steam Models - Alex Weiss, Kevin Walton [2021, EPUB]
Boiler Control Systems Engineering - G. F. (Jerry) Gilman [2010, PDF]
AALBORG Mission OM25 - Technical manual [1996, PDF]
Boiler Operator’s Guide - Ray Wohlfarth, Anthony L. Kohan [2021, PDF]
Boiler Control Systems Engineering - G. F. (Jerry) Gilman [2005, PDF]
The evolution of engineering in the Royal Navy. Vol. 1: 1827-1939 - Rippon, P.M. [1988, PDF]
Marine Engineering Diploma [2023, MP4]
Principles of Naval Engineering: Propulsion and Auxiliary Systems - Matthew A. Carr [2012, PDF]
Black & Decker The Complete Guide to Wiring, Updated 8th Edition: Current with 2020-2023 Electrical…
The time now is: Today 15:17
