skipper3362 ®   14-Feb-2025 20:29
Bentley STAAD pro structural Analysis Design Software
Year: 2020
Author: Udemy
Playtime: 5h 48m
Quality: WEB-DL
Format: MP4
Video codec: AVC/H.264
Audio codec: AAC
Video: 1920x1080
Audio: 44.1 KHz
Description: Professional Learning of Analysis and Design of Structure form basic to advanced course
What you'll learn
Introduction of STAAD Pro and Structural Engineering
Create/Modify Beam and Nodes
Apply Different Type of Load and Support to Structure
Apply Different Specification to Structure
Analysis and Design of Steel Structure
Analysis and Design of Concrete Structure
Analysis of Stare Case
Wind Load application to Multi Story Building
Earthquake Load application to Multi Story Building
Understand and interpretation of outcome/Results
Requirements
Basic knowledge of Structural Analysis and Design
Basic Knowledge of Drafting Software like AutoCAD
You should have basic understanding of computer.
Need Staad Pro Software. You can Download Academic Version.
Basic Understanding of Engineering Design
Know Codal Provision
Description
STAAD Pro stands for Structural Analysis and design. STAAD Pro v8i Software is widely used in analyzing and designing structures – buildings, bridges, towers, transportation, industrial and utility structures.Perform comprehensive analysis and design for any size or type of structure faster than ever before using the new STAAD.Pro V8i. Simplify your BIM workflow by using a physical model in STAAD.Pro that is automatically converted into the analytical model for your structural analysis. Share synchronized models with confidence for multi-discipline team collaboration and, most importantly, deliver safe, cost-effective designs.
Overview
Section 1: Introduction
Lecture 1 STAAD Screen Organisation
Section 2: Geometry Creation
Lecture 2 Create Geometry (add Beam and Node)
Lecture 3 Modifying Beam - Part 01
Lecture 4 Modifying Beam - Part 02
Lecture 5 Assign Property Support Specification
Lecture 6 Stretch Command
Lecture 7 Mirror Command
Lecture 8 Circular Repeat and Rotation Command
Lecture 9 Import CAD File
Lecture 10 Copy, Paste and Reference Command
Section 3: Load Application
Lecture 11 Apply Floor Load
Lecture 12 Basic Load Calculation in Building
Lecture 13 Apply Load to Plane Frame
Section 4: Analysis and Design of Steel Structure
Lecture 14 Structure Wizards
Lecture 15 How to Develop Truss
Lecture 16 Analysis of Truss using Snap Node Approach - Part 01
Lecture 17 Analysis of Truss using Snap Node Approach Part 02
Section 5: Analysis and Design of Concrete Structure
Lecture 18 Analysis of Simply Supported Beam
Lecture 19 Analysis of Overhanging Beam
Lecture 20 Analysis and Design of Portal Frame
Lecture 21 How To Analysis Staircase
Lecture 22 Elevated Water Tank Analysis
Section 6: Seismic Coefficient Method
Lecture 23 Earthquake Seismic Coefficient
Lecture 24 Shear Wall
Section 7: Response Spectrum Analysis
Lecture 25 Response Spectrum Analysis
Section 8: Time History Analysis
Lecture 26 Time History Analysis
Civil Engineer,Structural Engineer,Design Engineer
Bentley STAAD Pro Structural Analysis Design Software
Download [100 KB]
Advanced SACS Level III: Part 4 [2022, MP4]
Advanced SACS Level III: Part 1 [2022, MP4]
Advanced SACS Level III: Part 6 [2022, MP4]
Advanced SACS Level III: Part 3 [2022, MP4]
Advanced SACS Level III: Part 5 [2022, MP4]
SACS Software Course: Module 2 [2020, MP4]
Advanced SACS Level III: Part 2 [2022, MP4]
SACS Software Course: Module 1 [2022, MP4]
Cathodic Protection Corrosion Control System [2024, MP4]
Hydraulic Systems: A Complete Guide to Hydraulics knowledge - Udemy [2020, PDF]
The time now is: Today 18:05
