ClaireVoyant ®   12-Feb-2025 23:25
TAHA ASSALAM Annual DP Trials
Year: 2018
Author: Xing Wei Pte Ltd
Genre: Technical report
Pages count: 102
Description: Xing Wei Pte. Ltd, was requested to witness the 2018 Annual DP Trials on TAHA ASSALAM Offshore Support Vessel, at the field off Labuan Terminal Jetty. The request was made by Mr. Mahyuddin Bin Marisan from TH Alam Management Sdn Bhd. The tests are intended to investigate hardware redundancy, DP capability, software control and dynamic response after failures. The trials were witnessed by Mr. Chung Li Ann from Xing Wei Pte Ltd and class surveyor Mr. David Wong from BV.
The annual trial program has been developed from the FMEA of the vessel’s DP system and all related equipment. The trials are intended to show that the vessel meets the following requirements :
- BV – Part E Chapter 6 Section 10 Dynamic Positioning (DYNAPOS)
- IMCA M103 – Guidelines for the design and operation of dynamically positioned vessels
- IMO 113 – Guidelines for vessels with dynamic positioning systems 1994 (MSC 645)
- IMCA M212 – Example of an Annual DP Trials Report
- IMCA M190 – Developing and Conducting Annual DP Trials Programmes for DP Vessels
The annual DP trials demonstrated the vessel's ability to maintain position under normal circumstances and following major and minor equipment failures.
On the basis of the trials results, the vessel is considered to comply with the classification society as well as standard industrial requirements when operated within its defined operating limits and the DP system is configured as noted in section 2.4 of this report.
TAHA ASSALAM Annual DP Trials - Xing Wei Pte Ltd [2018].pdf
Download [9 KB]
PMS 17 Five-Yearly FMEA DP Trials Review - London Offshore Consultants [2018, PDF]
DP Technical and Operational Guidance Notes (TECHOP) Collection - Dynamic Positioning Committee [201...
DP Operations Guidance - Dynamic Positioning Committee [2021, PDF]
International Guidelines for the Safe Operation of Dynamically Positioned Offshore Supply Vessels - ...
Dynamic Positioning Failure Mode Effects Analysis Assurance Framework Risk-based Guidance (First edi...
Guidance on Failure Modes and Effects Analysis (FMEA) - IMCA [2016, PDF]
Guidelines for The Design and Operation of Dynamically Positioned Vessels - IMCA [2016, PDF]
BURBON LIBERTY 151~160 DP Operations Manual - The Dynamic Positioning Centre, C-MAR [2012, PDF]
DP Familiarization for Vessel Maintainers (DPVM) - Bram Offshore Transportes Marítimos [2020, PDF]
Rapid Response Damage Assessment program (RRDA) Collection - ABS [202x, PDF]
The time now is: Today 05:27
