ClaireVoyant ®   05-Feb-2025 04:40
Shipboard Propulsion, Power Electronics, and Ocean Energy
Year: 2012
Author: Mukund R. Patel
Genre: Practical guide
Publisher: CRC Press
ISBN: 1439888515, 9781439888513
Pages count: 379
Description: Shipboard Propulsion, Power Electronics, and Ocean Energy fills the need for a comprehensive book that covers modern shipboard propulsion and the power electronics and ocean energy technologies that drive it. With a breadth and depth not found in other books, it examines the power electronics systems for ship propulsion and for extracting ocean energy, which are mirror images of each other.
Comprised of sixteen chapters, the book is divided into four parts:
- Power Electronics and Motor Drives explains basic power electronics converters and variable-frequency drives, cooling methods, and quality of power
- Electric Propulsion Technologies focuses on the electric propulsion of ships using recently developed permanent magnet and superconducting motors, as well as hybrid propulsion using fuel cell, photovoltaic, and wind power
- Renewable Ocean Energy Technologies explores renewable ocean energy from waves, marine currents, and offshore wind farms
- System Integration Aspects discusses two aspects—energy storage and system reliability—that are essential for any large-scale power system
This timely book evolved from the author’s 30 years of work experience at General Electric, Lockheed Martin, and Westinghouse Electric and 15 years of teaching at the U.S. Merchant Marine Academy.
As a textbook, it is ideal for an elective course at marine and naval academies with engineering programs. It is also a valuable reference for commercial and military shipbuilders, port operators, renewable ocean energy developers, classification societies, machinery and equipment manufacturers, researchers, and others interested in modern shipboard power and propulsion systems.
The information provided herein does not necessarily represent the view of the U.S. Merchant Marine Academy or the U.S. Department of Transportation.
This book is a companion to Shipboard Electrical Power Systems (CRC Press, 2011), by the same author.
Additional info: See also:
https://seatracker.me/viewtopic.php?t=48234
Preface.................................................... xiii
Acknowledgments ........................................... xv
About the Author .......................................... xvii
About This Book ........................................... xix
Systems of Units and Conversion Factors ................... xxi
Part A Power Electronics and Motor Drives
Chapter 1 Power Electronics Devices ........................ 3
1.1 Diode ................................................. 7
1.2 Thyristor ............................................. 12
1.3 Power Transistor ...................................... 14
1.4 Hybrid Devices ........................................ 16
1.5 Di/Dt and Dv/Dt Snubber Circuits ...................... 17
1.6 Switching Power Loss .................................. 21
1.7 Device Application Trends ............................. 24
1.8 Device Cooling and Rerating ........................... 25
Problems .................................................. 26
Questions ................................................. 27
Further Reading ........................................... 27
Chapter 2 DC-DC Converters ................................. 29
2.1 Buck Converter ........................................ 29
2.2 Boost Converter ....................................... 36
2.3 Buck-Boost Converter................................... 38
2.4 Flyback Converter (Buck or Boost) ..................... 38
2.5 Transformer-Coupled Forward Converter ................. 40
2.6 Push-Pull Converter ................................... 41
2.7 Inductor-Coupled Buck Converter ....................... 41
2.8 Duty Ratio Control Circuit ............................ 42
2.9 Load Power Converter .................................. 42
2.10 Power Supply ......................................... 44
Problems .................................................. 46
Questions ................................................. 47
Further Reading ........................................... 47
Chapter 3 AC-DC-AC Converters .............................. 49
3.1 AC-DC Rectifier ....................................... 49
3.2 AC-AC Voltage Converter ............................... 62
3.3 DC-AC Inverter ........................................ 64
3.4 Frequency Converter ................................... 74
3.5 Thyristor Turnoff (Commutation) Circuits .............. 79
3.6 Other Power Electronics Applications .................. 81
3.7 Common Converter Terms ................................ 83
3.8 Notes on Converter Design ............................. 84
Problems .................................................. 87
Questions ................................................. 88
Further Reading ........................................... 89
Chapter 4 Variable-Frequency Drives ........................ 91
4.1 Pump Performance Characteristics ...................... 92
4.2 Pump Energy Savings with VFD .......................... 94
4.3 Shipboard Use of VFDs ................................. 98
4.4 VFD for Medium-Size Motor ............................. 98
4.5 Constant V/f Ratio Operation .......................... 101
4.6 Commutation and Control Methods ....................... 107
4.7 Open-Loop Control System .............................. 109
4.8 Vector Control Drives ................................. 109
4.9 Propulsion with a Twelve-Pulse VFD .................... 111
4.10 Special VFD Cables ................................... 111
4.11 Variable-Voltage DC Motor Drive ...................... 114
4.12 Variable-Speed Drive in Metro Trains ................. 116
4.13 VFD as Large-Motor Starter ........................... 117
4.14 Converter Topologies Compared ........................ 118
4.15 Notes on VFDs ........................................ 119
Problems .................................................. 121
Questions ................................................. 122
Further Reading ........................................... 122
Chapter 5 Quality of Power ................................. 123
5.1 Power Quality Terminology ............................. 123
5.2 Electrical Bus Model .................................. 125
5.3 Harmonics ............................................. 128
5.4 Power Quality Studies ................................. 140
5.5 Harmonic Reduction .................................... 141
5.6 IEEE Standard 519 ..................................... 151
5.7 International Standards ............................... 153
Problems .................................................. 153
Questions ................................................. 155
Further Reading ........................................... 156
Chapter 6 Power Converter Cooling .......................... 157
6.1 Heat Transfer by Conduction ........................... 157
6.2 Multiple Conduction Paths ............................. 159
6.3 Convection and Radiation .............................. 162
6.4 Thermal Transient ..................................... 164
6.5 Water Cooling ......................................... 165
Problems .................................................. 173
Questions ................................................. 174
Further Reading ........................................... 175
Part B Electric Propulsion technologies
Chapter 7 Electric Propulsion Systems ...................... 179
7.1 Current Status of Electric Propulsion ................. 180
7.2 Integrated Electric Propulsion ........................ 185
7.3 Azimuth Z Drive ....................................... 186
7.4 Azimuth Pod Drive ..................................... 187
7.5 Advantages of Electric Propulsion ..................... 189
7.6 Electric Propulsion Architecture ...................... 194
7.7 Motor Drives and Speed Control ........................ 197
7.8 Power Electronics Converters for VFD .................. 198
7.9 Propulsion Power Requirement .......................... 203
Questions ................................................. 207
Further Reading ........................................... 207
Chapter 8 Propulsion Motors ................................ 209
8.1 Synchronous Motor ..................................... 210
8.2 Induction Motor ....................................... 211
8.3 Permanent Magnet Motor ................................ 212
8.4 Superconducting Synchronous Motor ..................... 214
8.5 Superconducting Homopolar Motor ....................... 217
8.6 Other Motor Types ..................................... 221
8.7 Other Components ...................................... 223
8.8 Notes on Propulsion Motors ............................ 223
Questions ................................................. 224
Further Reading ........................................... 224
Chapter 9 Superconductors in Navy Ships..................... 225
9.1 Superconductivity ..................................... 225
9.2 Degaussing Coil ....................................... 226
9.3 Synchronous Machines .................................. 229
9.4 Superconducting Energy Storage ........................ 231
9.5 Industry Applications ................................. 234
9.6 Research Applications ................................. 235
9.7 Critical B, J, T of the Superconductor ................ 237
9.8 Coil Design and Cooling ............................... 239
Questions ................................................. 241
Further Reading ........................................... 241
Chapter 10 Fuel Cell Power ................................. 243
10.1 Electrochemistry ..................................... 244
10.2 Electrical Performance ............................... 247
10.3 Common Fuel Cell Types ............................... 250
10.4 Present and Future Use ............................... 252
10.5 Present Development Issues ........................... 257
Questions ................................................. 258
Further Reading ........................................... 258
Chapter 11 Hybrid Propulsion ............................... 261
11.1 Environmental Regulations ............................ 261
11.2 Hybrid Tugboat ....................................... 262
11.3 Hybrid Ferry ......................................... 264
11.4 Hybrid Automobile .................................... 267
11.5 Magnetohydrodynamics Propulsion in Ships ............. 268
Questions ................................................. 271
Further Reading ........................................... 271
Part C Emerging Ocean Energy technologies
Chapter 12 Ocean Wave Power ................................ 275
12.1 Wave Power Estimate .................................. 275
12.2 Power Generation Schemes ............................. 278
Questions ................................................. 286
Further Reading ........................................... 286
Chapter 13 Marine Current Power ............................ 287
13.1 Speed and Power Relations ............................ 288
13.2 Present Developments ................................. 295
Questions ................................................. 298
Further Reading ........................................... 298
Chapter 14 Offshore Wind Power ............................. 299
14.1 Wind Power Theory .................................... 300
14.2 Offshore Advantages .................................. 304
14.3 Power Transmission to Shore .......................... 304
14.4 AC versus DC Cable ................................... 306
14.5 Offshore Foundations ................................. 308
14.6 Farshore Foundations ................................. 312
14.7 Installations and Maintenance ........................ 313
14.8 Forces on Structure .................................. 315
14.9 Materials and Corrosion .............................. 315
14.10 Offshore Wind Power Trends .......................... 317
14.11 Environmental Regulations ........................... 319
14.12 International Safety Regulation ..................... 319
Questions ................................................. 320
Further Reading ........................................... 321
Part D System Integration aspects
Chapter 15 Large-Scale Energy Storage ...................... 325
15.1 Electrochemical Battery .............................. 325
15.2 Supercapacitor ....................................... 326
15.3 Rotating Flywheel .................................... 328
15.4 Superconducting Coil ................................. 333
15.5 Compressed Air ....................................... 334
Questions ................................................. 336
Further Reading ........................................... 336
Chapter 16 System Reliability Fundamentals ................. 337
16.1 Failure Mechanisms ................................... 337
16.2 Aging of Power Electronics Devices ................... 338
16.3 Failure Rate in Time ................................. 338
16.4 Random Failures ...................................... 339
16.5 Fundamental Theorems of Reliability .................. 341
16.6 Series-Parallel Reliability .......................... 341
16.7 Redundancies ......................................... 344
16.8 Failure Rate Statistics .............................. 346
16.9 Mil-Hdbk-217 ......................................... 347
16.10 Part Count Method of Reliability Estimate ........... 348
16.11 Derating for Reliability............................. 349
16.12 Quick Estimate of Failure Rate ...................... 349
16.13 Failure Modes, Effects, and Criticality Analysis .... 350
Questions ................................................. 350
Further Reading ........................................... 350
Index ..................................................... 351
Shipboard Propulsion, Power Electronics, and Ocean Energy - Mukund R. Patel [2012].pdf
Download [16 KB]
Shipboard Propulsion, Power Electronics, and Ocean Energy - Mukund R. Patel [2012, PDF]
VFD Challenges for Shipboard Electrical Power System Design - Mohammed M. Islam [2019, PDF]
Shipboard Electrical Power Systems, 2nd Edition - Mukund R. Patel [2021, PDF]
Guidance Notes for Control of Harmonics in Electrical Power Systems - ABS [2006, PDF]
Design of Shipboard Power System Grounding / Earthing - Norbert Doerry ,Mohammed M. Islam, John Prou...
Introduction to Power Electronics - Valery Vodovozov [2010, PDF]
Power electronics handbook - Muhammad Rashid [2011, PDF]
Practical Variable Speed Drives and Power Electronics - Malcolm Barnes [2003, PDF]
Foundation Course For Electrical Engineering Technician - 3G E-learning LLC [2021, PDF]
Electrical Engineer’s Reference Book - Sixteenth Edition - M.A. Laughton, D.J. Warne [2003, PDF]
The time now is: Today 00:12
