vitbar192 ®   23-Sep-2024 10:07
A basic manual for keelboat sailing at CSC
Year: 2023
Author: Burchik S. at all
Publisher: Cal Sailing Club
Pages count: 61
Description: So you’ve been messing about in dinghies for a while and have your Junior rating and you feel it’s time to start sailing on the keelboats. This is intended to be a guide to get you started, and also as a reference as you go through the CSC keelboat lesson series or when geęing private instruction. The material covered in this manual will continue to build on the basics learned in dinghies, with aęention called to some of the big differences between the two. A keelboat is slower to respond, has a greater turning radius and, with a large mass, momentum will be a big factor in how the boat behaves. The fundamentals are not going to be covered here, as they are thoroughly discussed in Colgate and other basic sailing books listed at the end of this manual. The most important skills to be learned are: recognizing what the boat will be doing before it happens
and planning maneuvers before executing them. Having a thorough understanding of basic sail mechanics will also be a good starting point for learning to sail keelboats.
Burchik S. at all A basic manual for keelboat sailing at CSC, 2023.pdf
The Complete Sailing Manual - Revised and Updated - Steve Sleight [2015, PDF]
Learn to sail - Boulva K, Roux-groleau J.- P. [2010, PDF]
Performance Sailing and Racing - Steve Colgate [2012, EPUB]
The Rules Book. The 1981-84 International Yacht Racing Rules Explained - Twiname E.,…
Starting a scratch-build using The Anatomy of the Ship - Rich Brayshaw [2009, PDF]
Basic sailing and cruising skills - Rob MacLeod [1987, PDF]
RYA Competent Crew Skills - Jon Mendez [2014, PDF & DOC]
Learning to Sail: A No-nonsense Guide for Beginners of All Ages - Learning to Sail: A No-nonsense…
Sailing: A Beginner’s Guide: The Simplest Way to Learn to Sail - Tim Hore [2021, EPUB]
A Practical Guide to Rudderless Sailing - Hacket A. [2019, PDF]
The time now is: Today 16:48
