vitbar192 ®   23-Aug-2024 08:27
The Elements of Boat Strength Scantling System
Year: 2010
Author: Gerr D.
Publisher: CEng FRINA
Pages count: 46
Description: It has been over 10 years since The Elements of Boat Strength was published in 2000. In all that time and all the many, many boats built to this rule, I have yet to learn of a single structural failure.
That’s a pretty good record. As The Elements of Boat Strength scantling system now has a ten-year history of successful use and is quite simple to apply, it seems a good time to review what the rule is, how it came to be, how it should be applied and how it relates to a few other scantlings. We’ll also look at some of the things I’d adjust in The Elements of Boat Strength scantling system.
Since almost everything in this system references the “scantling number” (Sn), I’ll refer to it as the “Sn scantling system,” “Sn system or rule,” or the “Sn process.” Also—as I’ll explain—I have used aspects of this basic system for years before the book’s publication.
Not
Gerr D. The Elements of Boat Strength Scantling System, 2010.pdf
Download [7 KB]
The Elements of Boat Strength: For Builders, Designers, and Owners - Dave Gerr [1999, PDF]
Ultralight Boatbuilding - Hill T.G. [1987, PDF]
Requirements for Building and Classing Floating Offshore Liquefied Gas Terminals - ABS [2024, PDF]
Fishing boat designs 2. V-bottom boats of planked and plywood construction - Øyvind Gulbrandsen…
Rules for Bulk Carriers and Oil Tanker - Indian Register of Shipping [2023, PDF]
U-Boats : History, Development and Equipment, 1914-1945 - D.M.O. Miller [2000, PDF]
Rudder v.1.5.i - BV [2021]
10 Wooden Boats You Can Build. For Sail, Motor, Paddle and Oar - Spectre P.H. [1995, PDF]
Plain Sailing. Learning to See Like a Sailor - A Manual of Sail Trim - Murphy D. [2010, PDF, EPUB]
Safety Digest Lessons from Marine Accident Reports No 1/2020 - MAIB [2020, PDF]
The time now is: Today 13:19
